LS/VTEC HG question?
Old Sep 8, 2003 | 01:39 PM
Forrest Gump 9's Avatar
Default LS/VTEC HG question?
Hey guys. Bad news for me. I think I've just blew the HG on my LS/VTEC. It was due thought. I was just wanna know what would be a good HG (brand?) to replace with. I think I'm gonna go ahead and get the ARP studs too. My engine is a 96 LS block with a PR3 head, so what kinda HG I should get (LS or SI)? Thanks for the replies.
Old Sep 8, 2003 | 04:18 PM
Default Re: LS/VTEC HG question? (PaintStripper)
Com'on, no help??
Old Sep 8, 2003 | 04:22 PM
HybriDNA's Avatar
I hope you used the LS HG because you can't use a vtec one. Go with a OEM LS HG or aftermarket.
Old Sep 8, 2003 | 04:29 PM
Default Re: LS/VTEC HG question? (HybriDNA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybriDNA &raquo;</TD></TR><TR><TD CLASS="quote">I hope you used the LS HG because you can't use a vtec one. Go with a OEM LS HG or aftermarket.</TD></TR></TABLE>
Can anyone confirm on this? The reason I ask is I bought the car with LS/Vtec. I didn't build it.
Old Sep 9, 2003 | 07:06 AM
One more question. Do I use the LS head studs or the Si one? I didn't know they were different either. Thanks!!
Old Sep 9, 2003 | 07:51 AM
HybriDNA's Avatar
You can only use b series Vtec headstuds because the head is taller. I recommend the headstuds from ARP.
Old Sep 9, 2003 | 08:02 AM
I'm sorry I didn't clarify. ARP have two versions of B18a and B18c head studs. Which one should I use? Thanks again!!
Old Sep 9, 2003 | 08:40 AM
Rpc07's Avatar
[QUOTE=PaintStripper]
Can anyone confirm on this?QUOTE]
yes you can only use the ls headgasket... i have an LS/Vtec and tried to use a vtec headgasket but it didnt work. the ls is the only one you can use. you should get some ARP headstuds too... i have them, they are awesome
Old Sep 9, 2003 | 11:04 AM
Shft@9GSR's Avatar
B18C headstuds. VTEC head is taller, thus longer studs are needed.
Old Sep 9, 2003 | 11:31 AM
mmuller's Avatar
Mad Scientist
Default Re: LS/VTEC HG question? (Shft@9GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shft@9GSR &raquo;</TD></TR><TR><TD CLASS="quote">B18C headstuds. VTEC head is taller, thus longer studs are needed.</TD></TR></TABLE>
Old Sep 9, 2003 | 12:02 PM
rice_n_me's Avatar
COMETIC.........
Old Sep 9, 2003 | 01:03 PM
redlinegsr's Avatar
Default Re: LS/VTEC HG question? (mmuller)
HONDA OEM part rule
Old Sep 9, 2003 | 03:32 PM
zCivic's Avatar
Default Re: LS/VTEC HG question? (redlinegsr)
Accually get the LS head gasket. Any year is fine. I got one from a guy on e-bay no problems from it. It was a ''Stone''. Get the B18C head studs. Not all v-tec head bolts are the same. B16/B17 head bolts are 11mm*155mm while C1's and C5's are 11mm*164mm and it will make a difference. I just used B18C1/C5 head bolts from honda. I've never heard of any problems with the head bolts even on higher boosted cars.
Old Sep 9, 2003 | 06:56 PM
Default Re: LS/VTEC HG question? (zCivic)
Thanks for the replies guys!! I've just put in an order for the ARP B18C head studs. I'm gonna go down to the local Acura dealer and get my LS HG tomorrow. I eventually wanna go turbo on this "bastrdize". It's never fast enough, I'm just taking it one step at a time.
Old Sep 9, 2003 | 07:35 PM
HybriDNA's Avatar
Sounds like your on the right track Good luck with your beast!
zenon8890
Dec 22, 2005 10:31 PM
JDMJunior
Dec 17, 2005 11:05 AM
integra racr04
Aug 17, 2004 01:25 AM
RSVTECDC4
Jul 19, 2003 06:05 AM
xstalkrx
May 17, 2003 03:56 AM
