What Would Make Vtec NOT kick in??? 99 Si HELP!!!!
Old Sep 8, 2003 | 10:50 AM
DumpedSi's Avatar
Default What Would Make Vtec NOT kick in??? 99 Si HELP!!!!
I have a 99 si, everything seems to work great and the car runs fine but the only problem is vtec doesnt kick in.. Anyone have any idea why it wouldnt kick in like its suppose to???
Old Sep 8, 2003 | 10:52 AM
RickChew's Avatar
Default Re: What Would Make Vtec NOT kick in??? 99 Si HELP!!!! (Slammed Si)
Check your oil level. Rick
Old Sep 8, 2003 | 10:53 AM
wilsel's Avatar
^ what he said
Old Sep 8, 2003 | 11:58 AM
Mr Boston's Avatar
Default Re: (wilsel)
Do you have a cel? Sometimes it makes u go into limp mode and vtec will not kick in
Old Sep 8, 2003 | 12:02 PM
Archidictus's Avatar
Unceasing Measure
Default Re: (Integra Type R)
Odds are your oil level is real low and you're not getting sufficient oil pressure to make the VTEC solenoid do its ****.
99civic_exSB's Avatar
Maybe somebody just stuck Si stickers on it and it's really a DX. Haha.
Old Sep 8, 2003 | 12:06 PM
B16A2-EM1's Avatar
Default Re: (99civic_exSB)
Vee-Tack Solenoid has not reached operating temp... Let the bish warm up before you bag it.
Old Sep 8, 2003 | 12:28 PM
97itr86's Avatar
Default Re: (B16A2-EM1)
speed sensor?
Old Sep 8, 2003 | 12:52 PM
DumpedSi's Avatar
Default Re: (97itr86)
I have no CEL's, the car is upto temp. and the oil level looks good... Any other suggestions??
Old Sep 8, 2003 | 12:55 PM
RyanEJ8's Avatar
Water temp could be causing it too. Make sure your engine is warmed up all the way.
Old Sep 8, 2003 | 01:02 PM
BauleyCivic's Avatar
Risky Business
Default Re: What Would Make Vtec NOT kick in??? 99 Si HELP!!!! (RyanCivic2000)
are you sure its not engaging? is the rev limit much lower?
Old Sep 8, 2003 | 01:08 PM
DumpedSi's Avatar
I let the car run for an hour before I tried it and it didnt kick in....
It will go all the way upto 8 grand with no vtec
Old Sep 8, 2003 | 01:13 PM
GDM Z28's Avatar
ho do you know its not kicking in? maybe you are just use to it now.
Old Sep 8, 2003 | 01:26 PM
00MRSi's Avatar
Default Re: What Would Make Vtec NOT kick in??? 99 Si HELP!!!! (civicflnum1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicflnum1 &raquo;</TD></TR><TR><TD CLASS="quote">ho do you know its not kicking in? maybe you are just use to it now.</TD></TR></TABLE>
My thoughts too. If oil level is fine, and operating temp is fine, then maybe your VTEC solenoid took a crap on you..
Old Sep 8, 2003 | 01:36 PM
DumpedSi's Avatar
Default Re: What Would Make Vtec NOT kick in??? 99 Si HELP!!!! (00MRSi)
I bought it from an auction missing the motor.. I got the block from my friend and got the head and tranny from a shop.. Everything was slapped together but no vtec. Trust its not that Im used to it.
Old Sep 8, 2003 | 01:39 PM
redline201's Avatar
try this
https://honda-tech.com/zerothread?id=164863
Old Sep 8, 2003 | 01:40 PM
ProEater's Avatar
check the selonoid (sp) is everything connected? also bring i back to damn shop. and btw vtec was quiet when i was stock slap an intake on and see if you can hear it
Old Sep 8, 2003 | 01:48 PM
DumpedSi's Avatar
Default Re: What Would Make Vtec NOT kick in??? 99 Si HELP!!!! (ProEater)
has intake
DumpdEJ6
May 8, 2019 07:23 AM
Chpwhtek
Mar 19, 2012 04:48 PM
502em1
13
Apr 18, 2007 10:53 AM
GiT LaO'd
Nov 22, 2004 04:24 AM
99scivic
Jun 1, 2004 11:09 PM
