Brake pads, whats the difference in these- Hawk HPS & Ultimates
Old Sep 8, 2003 | 09:51 AM
Bbasso's Avatar
Default Brake pads, whats the difference in these- Hawk HPS & Ultimates
What is the difference between the Axis ultimates and Hawk HPS?
Which is a more aggressive pad, which needs more heat, causes more rotor wear, and all the other stuff?
any real world experiences would be great.
Old Sep 8, 2003 | 12:05 PM
Bbasso's Avatar
Default Re: Brake pads, whats the difference in these- Hawk HPS & Ultimates (Bbasso)
Did I ask something that hard? Or the right people have not logged on yet?
Old Sep 8, 2003 | 12:16 PM
Muckman's Avatar
Moderator in Chief
Call Andy Lin at cobaltfriction.com
He will break it down for you in detail.
In my opinion the Axxis Ultimate is a better pad in all areas you mentioned.
Old Sep 8, 2003 | 12:21 PM
Bbasso's Avatar
Default Re: Brake pads, whats the difference in these- Hawk HPS & Ultimates (Muckman)
Really the ultimates are better? Holy cow. I thought it was the other way around.
Old Sep 8, 2003 | 02:08 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
I believe the Ulitmates are a step above the HPS. I run the HPS pads as well and like them alot. A little more aggressive than the stock pads and great for street/auto-x. In terms of track use the Ultimates are better in every aspect if I'm not mistaken, but cost more.
Old Sep 8, 2003 | 02:18 PM
bus stop's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">Really the ultimates are better? Holy cow. I thought it was the other way around.
there's a "chart" on Cobalt's web site to lay out the perfromance of different brake pad, you can use it as a reference.
Old Sep 8, 2003 | 04:07 PM
frogsr's Avatar
between the two pads you've listed, the axxis ultimate is the better pad for the track. the hps in my opinion is a great street pad, period. anything above moderate track use will cause the hps to fade and make you laugh before getting into the turns while (trying) slowing down... the axxis ultimate is great for the street as well as light duty track use, but will dust almost two times more than the hps. as far as rotor friendliness, they are probably very similar.
and yes, andie is a great resource!
Old Sep 8, 2003 | 05:05 PM
1GreyTeg's Avatar
Default Re: Brake pads, whats the difference in these- Hawk HPS & Ultimates (WhosITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhosITR &raquo;</TD></TR><TR><TD CLASS="quote">
there's a "chart" on Cobalt's web site to lay out the perfromance of different brake pad, you can use it as a reference.</TD></TR></TABLE>
http://www.cobaltfriction.com/products/hawk.htm
http://www.cobaltfriction.com/...e.htm
A. who just recieved his new rotors and went with GT-R spec VR's this time around.
Who else has Half life Hawk blues and or Ram's pads as backups? But, after my scary experience at the Beaver with my brakes, I'm playing super safe, all new everything and bled the fluid correctly.
Modified by 1GreyTeg at 6:34 PM 9/8/2003
Old Sep 8, 2003 | 05:38 PM
Bbasso's Avatar
Great, thanks for posting everyone!
My question is answered.
Old Sep 8, 2003 | 06:32 PM
Tweakmeister's Avatar
Default Re: (Bbasso)
I'm hoping Andie will swing by the thread.
What is the recommended bedding for the Ultimates on new rotors? My card is lost...and searching the archives reveals many different techniques.
Old Sep 8, 2003 | 08:08 PM
1GreyTeg's Avatar
Default Re: (Tweakmeister)
This Baer link seems to have the clearest and most consistant directions with how to bed in street/ track pads:
http://www.baer.com/Support/Te...pID=5
Their Race pad bedding in is just a bit different albeit more agressive with less concern for longevity.
But, clearly after reading their site and descriptions, there are absolute differences to seasoning rotors and bedding in pads.
After reading many postings here recently from the Archives (both in RRAX & ITR forums) about Rotors, Pads, bedding in and wear, I see most people may not be properly seasoning their rotors or never seasoning them at all but, only bedding in the pads which seems to be only half the procedure when swapping on new rotors and new pads.
The Baer site also clearly states that seasoning rotors should be done with already used pads and only after the seasoning of the rotor and proper cooling should you bed in the new pads.
As well it says that rotor wear/life is what will be affected directly when not properly seasoning/bedding in.
Here is the home tech link: http://www.baer.com/Support/TechTips.aspx
I too would love to hear from Andie, he is good people
Old Sep 8, 2003 | 08:19 PM
thk's Avatar
thk
Members Only
Default Re: (1GreyTeg)
Thanks for the link Anton.
I guess I should really put on the replacement rotors I have sitting around so that I can "season" them before Watkins. Now I understand why you're supposed to go easy on the brakes when you buy a new car or replace your rotors.
B serious
Honda S2000
23
May 1, 2007 05:23 PM
B18c5__Owns
Mar 24, 2006 01:08 PM
jolt-tsp
Suspension & Brakes
14
May 23, 2005 06:56 PM
Tad
28
Feb 3, 2005 04:25 PM
Xia0w0ng
Jul 12, 2002 01:30 PM
