INJEN CAI (problem)
Old Sep 8, 2003 | 09:29 AM
lastlude2k1se's Avatar
Default INJEN CAI (problem)
Just installed an INJEN CAI on a type-S a few days ago. Everything seemed fine, had it dynoed and all.
Just yesterday the check engne light kept lighting up, any ideas to why? Would it be related tot he CAI at all? I will check the MAF sensor later, hopefully it's just that but could it be anything else if it's not the MAF?
Old Sep 8, 2003 | 10:50 AM
kryzeofkrayzie's Avatar
Default Re: (ek9psi)
Most likely one of the sensor's clips are disconnected i had this problem with sri, but i made sure every sensor and clip was connected when i did my injen cai.
Old Sep 8, 2003 | 11:05 AM
Default Re: (kryzeofkrayzie)
Well when installing the CAI you have no choice but to reset the ECU b/c you have to disconnect the battery to install it. I can't think of anything but the MAF poping out, hopefully that's all it is. Thanks
Old Sep 8, 2003 | 05:14 PM
ek9vboi
Guest
Posts: n/a
hum....weird. i put a aem cold air into my lil bro's civic and we didnt have to d/c the battery. it was bitsh to do, but i did it. we had no check lights, no resetting ecu...nothing. maybe i think the o2 sensor has something to do with it. is it possible that you could have broken it in anyway? well good luck, get back to me on your problem.
Old Sep 9, 2003 | 07:36 AM
Default Re: (ek9vboi)
Ok the MAF was plugged in properly, so I disconnected the neg battery terminal again and also pulled out the hazard light fuse for about 20 minutes......when I put everything back together the CEL did not come back on, I also let the car idle for 20 minutes. So far so good, hopefully it will stay this way. Thanks
Old Sep 10, 2003 | 07:59 AM
Default Re: (lastlude2k1se)
Ok, the CEL has come back on after less than 24 hours of disconnecting the neg battery terminal and resetting the CEL light by pulling out the hazard fuse. Any ideas as to why this is happening?
If there was a sensor that was damaged, I don't think that the CEL would go away even after disconnecting the NEG battery terminal.
Old Sep 10, 2003 | 11:34 AM
No one knows?
Old Sep 10, 2003 | 01:05 PM
ek9vboi
Guest
Posts: n/a
beats the hell outta me. so when u d/c the oem intake, there was 2 hoses and one plug like thing right? thats what the si got. um...did you reattach both hoses to where they were to go? did you try to lub up the sensor? some instuctions tell you to do this and this ***** the sensor up in a way. well get back to me
Old Sep 10, 2003 | 01:27 PM
Yeah I double checked the 2 hoses and the MAF sensor, and they were all fastened properly. I did not lube up the sensor either. ??????????
Old Sep 10, 2003 | 01:50 PM
ek9vboi
Guest
Posts: n/a
ok, try this. pu the stock oem intake back in and see if it reacts. if nothing happens then that means something wrong with your intake. other then that i dont know ahst up with your ride mang
Old Sep 10, 2003 | 01:58 PM
Aight, thanks for the help dude.
ddrakiotes
Honda Civic (2006 - 2015)
Sep 6, 2007 12:42 PM
2fasttypes
Jul 12, 2007 09:45 AM
Ideal R
Mar 30, 2003 07:39 AM
N~FaMouSKhMerBoi
Sep 18, 2002 12:42 PM
GSRacer2102
Feb 24, 2002 12:05 PM
