I HAVE A PROBLEM ...ONCE AGAIN!
Old Sep 8, 2003 | 06:39 AM
HATCHFREEK's Avatar
Default I HAVE A PROBLEM ...ONCE AGAIN!
SUP PEEPS...
Well im now running a P28 Mugen Power ecu. as im runnig i get a cel code. codes are 7/ 10.. what could be causing it.. by the way im running a 93 eg wit a 98 gsr wit a si tranny . jg elderbrock im. and a type r t/b ... MAYBE THIS WILL HELP... ( OR NOT) THANKS
Old Sep 8, 2003 | 10:35 AM
HATCHFREEK's Avatar
Default Re: I HAVE A PROBLEM ...ONCE AGAIN! (HATCHFREEK)
ANYONE?
Old Sep 8, 2003 | 10:48 AM
mmuller's Avatar
Mad Scientist
code 7=TP Sensor (Throttle Position)
defective circuit or unplugged / defective sensor
code 10=IAT Sensor (Intake Air Temperature)
so what do you think is wrong???
Old Sep 8, 2003 | 11:11 AM
Katman's Avatar
have you mis-connected the TPS sensor plug into another plug of the same type by accident? usually the TPS & MAP sensor plugs have the same exact plug type.
Also, for the IAT sensor, make sure you don't accidently have the EGR valve plug, plugged into your IAT sensor. Those 2 plugs can easily be confused cuz they look the same.
efyou999
May 24, 2012 12:21 AM
viking-101
19
Apr 14, 2012 04:38 PM
sh!ft
May 13, 2009 01:18 PM
jpangeles
Sep 12, 2004 05:23 PM
