MSD Soft Touch Rev Control - part# 8728 - need help installing in LS/Vtec
Old Sep 8, 2003 | 06:38 AM
.y2a.'s Avatar
Default MSD Soft Touch Rev Control - part# 8728 - need help installing in LS/Vtec
Bought this part and cannot figure out how to install it. The PDF file on their site is not very clear on how to install this into a Honda.
http://www.msdignition.com/pdf/pn8728.pdf
Can anyone help??
Old Sep 8, 2003 | 10:59 AM
AllmotorJunkie's Avatar
Default Re: MSD Soft Touch Rev Control - part# 8728 - need help installing in LS/Vtec (.y2a.)
MSD product installation manuals are crap. I bought an MSD shift light for $75 & followed the instructions to install it....NOthing worked. Nothing worked cause (3) resistors all because the wiring diagram is crap!
I would have someone that knows how to do it...do it for you. I wouldn't risk doing it on your own if you are not sure what to do.
Old Oct 1, 2003 | 01:04 AM
shant's Avatar
Default Re: MSD Soft Touch Rev Control - part# 8728 - need help installing in LS/Vtec (AllmotorJunkie)
It seems that only the coil + and - wires need to be taped into for this product to work,
http://www.msdignition.com/pdf/pdf23.pdf if you look at the distributor in the link there is c- and c+ wires. i assume this means coil negative and coil positive. are these the only wires that i need to tap into?
instructions for MSD Soft Touch Rev Control PN 8728 here
on page 6 is late modle dodge ignition, i was told this is like a honda ignition and to look at this diagram, you can see that the red and green wires tap into the origintal coil wires. it seems that this is all i need to do to add the rev control?
is this correct for a honda ignition system, anyone else ever install this product on there stock honda ignition.
any help would be apreciated as i need this installed before the weekend. thanks
Old Sep 2, 2004 | 04:55 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: MSD Soft Touch Rev Control - part# 8728 - need help installing in LS/Vtec (shant)
Bump - Did you get it installed? How does it work? I'm about to get one for myself.
Eg_TypeR
Mar 17, 2006 11:44 AM
dingusjt
Mar 10, 2003 12:13 PM
batboy18
Aug 26, 2001 05:01 PM
