camber kit.. these any good?
Old Sep 7, 2003 | 09:24 PM
tangb2023
Guest
Posts: n/a
Default camber kit.. these any good?
http://cgi.ebay.com/ebaymotors...49360
my camber only 1 degree off
Old Sep 7, 2003 | 09:32 PM
daaznwhiteboi's Avatar
Default Re: camber kit.. these any good? (tangb2023)
Mmmm im not sure if those r ne good, but i dont think that 1 degree is alot, but im not sure, just wut iv heard... sry cant be ne more help.
Old Sep 7, 2003 | 09:46 PM
BauleyCivic's Avatar
Risky Business
Default Re: camber kit.. these any good? (daaznwhiteboi)
if its only a degree off dont worry about it
Old Sep 7, 2003 | 09:51 PM
R6Elmo's Avatar
Did you get an alignment? How much camber do you have up front? You are 1 degree off as in.....???
Don't buy from that guy. I got a kit from him, and they aren't the same ones pictures. He pictures an ingalls type kit, but he sells the type where you just place the bolt in either one of two spots. Not much adjustablility. Slow shipping too.
Old Sep 7, 2003 | 11:00 PM
Del Sol SiR's Avatar
I bought this PL8 kit for my Del Sol, not sure if it was the same seller... I installed it and took it to the aligniment shop, worked out great, perfectly straight. Only one problem, when I drive over small bumps n' stuff I hear a creaking noise coming from the driver's side wheel area. The alignment shop says its the bushings in the camber kit, they're tight... I'll lube it in the morning...
Old Sep 8, 2003 | 08:28 PM
tangb2023
Guest
Posts: n/a
Default Re: camber kit.. these any good? (DelSolSiR)
thanks for the response.. no 1 degree is not much.. but my tires would at least have about 10,000 more miles worth because of bad camber.. i just cant afford good ones. delsolsir. how many degrees does it adjust??. keep me posted.. for 20 bucks.. it is worth the buy. anyone else??
2point2
Sep 28, 2006 04:27 PM
AB16A2T
31
Oct 15, 2002 09:36 AM
watacivic
13
Oct 8, 2002 09:15 PM
LS Teg
May 10, 2002 10:18 AM
OR-G
Jan 31, 2002 01:44 PM
