Which kit ADDS negative camber and CASTER?
Old Sep 7, 2003 | 08:49 PM
Jason C SBB's Avatar
Default Which kit ADDS negative camber and CASTER?
I have a '97 HX with Konis and H&R OE Sports, and am waiting for my swaybars to arrive. Car is not slammed.
I'm now looking into a camber kit to make camber and caster adjustable. I want to increase camber to improve cornering grip. As I understand it, increasing caster will also increase negative camber with steering lock.
Is SPC the only kit that can adjust both camber and caster?
TIA
Old Sep 8, 2003 | 08:09 AM
Phoenix_ITR's Avatar
Default Re: Which kit ADDS negative camber and CASTER? (Jason C SBB)
you can pick up a little bit of caster adjustment by buying the skunk2 adjustable upper control arm and swapping the arms left to right. i've seen this done a couple of times -- the only problem comes from some instances of the UCA contacting the fenderwell, but since your car isn't slammed, it shouldn't be a problem.
as i mentioned, this kit will allow for camber adjustments, but after you've swapped the arms, there's no other way to play with caster. hope this helps...
-tony
garyc17
Apr 17, 2008 08:38 AM
b18LS
Suspension & Brakes
Apr 18, 2007 06:05 AM
JRTegman987
Suspension & Brakes
Oct 22, 2006 11:38 PM
RedlineRex
Aug 3, 2006 04:37 AM
lsvtec_DA
Feb 25, 2004 09:59 PM
