Fixing Fuel main relay
Okay, I've heard there was a way to fix it by soldering? I know the fuel wire is green and white, but that's about all I know. Has anyone here ever fixed it this way before? Or do I have to just simply replace it?
to actually fix the relay, you need to pop open the relay casing.
then look for the place where the solder has broke, and then clean it and resolder.
a little work, but cheaper than buying a new one.
yes its plug and play, a new one from http://www.hondaautomotiveparts.com is about $50
Thanks, but I'm starting to suspect it is NOT the main fuel relay. The car started up today, and had 32psi of pressure the whole time (at idle). It normally has 38. So I think my fuel pump may be going out, since the Main relay doesn't control pressure, right? Or am I wrong?
DEEGORILLA06
Jul 12, 2006 12:54 PM
RAB
Oct 11, 2004 05:44 PM
