Noob question.. .25 overbore pistons on a stock bore block?
Old Sep 7, 2003 | 06:07 PM
Captn. Save A Hoe's Avatar
Default Noob question.. .25 overbore pistons on a stock bore block?
my friend wants to run .25 overbore ITR pistons on a LS bloc with stock bore.. can it be done?
chris
Old Sep 7, 2003 | 06:40 PM
dwn-shift's Avatar
Default Re: Noob question.. .25 overbore pistons on a stock bore block? (The P.I.M.P)
Sure, anything can be done with a sledgehammer. For it to work properly you need to have the block bored out .25, and have it honed.
Old Sep 7, 2003 | 09:03 PM
hndarcrb18c1's Avatar
Default Re: Noob question.. .25 overbore pistons on a stock bore block? (dwn-shift)
[QUOTE=dwn-shift]Sure, anything can be done with a sledgehammer. LOL....
Old Sep 8, 2003 | 07:55 AM
irev210's Avatar
Default Re: Noob question.. .25 overbore pistons on a stock bore block? (hndarcrb18c1)
depending on how old the motor is, you could make the pistons physically fit, but the clearences would be VERY wrong, and you'd score the **** out of your cylinder walls.
In all, you need to bore to spec, then hone
slammedef06
Apr 8, 2013 09:16 PM
EGandDArida
Sep 5, 2009 04:51 PM
igotthaspirit
Nov 9, 2006 07:11 AM
Chris Benoit
Aug 10, 2003 09:22 PM
Captain Save-a-Hoe
May 10, 2002 07:42 PM
