Cheap and easy power.
Old Sep 7, 2003 | 04:36 PM
Hites
Guest
Posts: n/a
Default Cheap and easy power.
ive got the usual i/h/e, a modified cat, suspension, and im planning on getting a jrsc soon. i dont really know what to get for my car now. what some cheap and easy to swap in or install things to get just a little more kick out of my b18b. im not looking for a turbo, nitrous, or higher boost pulleys.
Old Sep 7, 2003 | 04:39 PM
T4eg's Avatar
Default Re: Cheap and easy power. (Hites)
i would go turbo over JRSC. IMO jrsc sucks. Thats just my 2 cents
Old Sep 7, 2003 | 05:27 PM
Hites
Guest
Posts: n/a
Default Re: Cheap and easy power. (BlueHatch00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueHatch00 &raquo;</TD></TR><TR><TD CLASS="quote">i would go turbo over JRSC. IMO jrsc sucks. Thats just my 2 cents</TD></TR></TABLE>
gee, what a surprise! a turbo advocate just shooting off his mouth like ive heard a billion times before! this doesnt even apply to the topic at hand.
Old Sep 7, 2003 | 08:57 PM
9200RPM's Avatar
Try N2o.....JRSC don't suck...you just dont have a cool intake charge...if you did a JRSC and sprayed a small shot then the problem would be solved....Who cares how you make the power as long as it's there....
Old Sep 7, 2003 | 09:15 PM
B16OnTop's Avatar
Default Re: Cheap and easy power. (TurboB16aEG)
yea just get like a 25 shot so you have a cooler charge of air going in
Old Sep 8, 2003 | 03:05 AM
97hb's Avatar
Get some cams and get it tuned. Otherwise I'd say nitrous.
Old Sep 8, 2003 | 07:57 AM
StyleTEG's Avatar
Default Re: Cheap and easy power. (97hb)
Better Tires
weight reduction
motor mounts
Old Sep 8, 2003 | 08:29 AM
roadawg's Avatar
Default Re: Cheap and easy power. (StyleTEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StyleTEG &raquo;</TD></TR><TR><TD CLASS="quote">Better Tires
weight reduction
motor mounts</TD></TR></TABLE>
None of those things you listed will make power.
I would say a set of cams, but you said "cheap power", if there is such a thing.
Old Sep 8, 2003 | 09:50 AM
StyleTEG's Avatar
Default Re: Cheap and easy power. (SiRWanabe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRWanabe &raquo;</TD></TR><TR><TD CLASS="quote">
Because at this point he has nothing left to do besides get the JRSC.
Cams are a BAD idea for FI, because NA cam design and FI cam design are not the same and you want different things.
Aftermarket cams are going to increase overlap, which is exactly the opposit of what he wants for a JRSC application. What happens when you have more overlap? More boost goes straight in from the intake valves straight out through the open exhaust valves.
All of the things I listed will increase acceleration, the same goal is acheived just by different methods.
Old Sep 8, 2003 | 10:26 AM
9200RPM's Avatar
About the cam issue...If I'm correct, Comp cams don't have much overlap, and have hella lift...I have the 57200's in my B16. They are great all motor and better on N2o....I don't know how they will work on Boost....But I'd like to know...
Old Sep 8, 2003 | 11:07 AM
StyleTEG's Avatar
N2O and Boost want the same thing from cams, the more overlap you have the more N2O that is going to be shot straight into the exhaust ports.
N2O is a form of boost. It does the same thing as any other form of FI just by different means.
If you look at cam manufactures specs, the more aggressive the cams get (designed for NA) you will notice not only is lift increased but duration (and thus overlap) is as well. If you look at crowers website, you will notice each stage bumps up the duration and lift together. While the turbo forumulated cams tend to have close to stock duration.
Old Sep 8, 2003 | 12:06 PM
Hites
Guest
Posts: n/a
weight reduction
already got the wheels and tires. its a daily driver and i usually haul 1 or 2 people most days so weight reduction isnt all that practical. the types of things i was thinking about were like different plugs and wiring; kinda like engine dress up that actually serves a purpose is what im looking for.
Old Sep 8, 2003 | 12:39 PM
9200RPM's Avatar
If your really wanting to make power....Small stuff like that isn't gonna get you there....Might make the car run better but not much faster...
Old Sep 8, 2003 | 12:59 PM
GPwhiteDB8's Avatar
i like the motor mount idea......puts down quicker stronger power without that flex.....helps ur launch. may not technically make more power, but it does add speed. why u gotta rip on the guy?
Old Sep 8, 2003 | 01:14 PM
Hites
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboB16aEG &raquo;</TD></TR><TR><TD CLASS="quote">If your really wanting to make power....Small stuff like that isn't gonna get you there....Might make the car run better but not much faster...</TD></TR></TABLE>
sure, fine, now throw out some of them.
Old Sep 8, 2003 | 01:31 PM
EX-T's Avatar
try a ground strap set. it's not really all that cheap though but a lot of people i have talked to say that they can tell a difference in throttle response. :shrugs: just a thought.
Old Sep 8, 2003 | 02:16 PM
Turbo Rex's Avatar
Default Re: Cheap and easy power. (DSeriesBKilla)
How's this.... You get what you pay for.....
Old Sep 8, 2003 | 02:29 PM
roadawg's Avatar
Default Re: (votebam1090)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by votebam1090 &raquo;</TD></TR><TR><TD CLASS="quote">i like the motor mount idea......puts down quicker stronger power without that flex.....helps ur launch. may not technically make more power, but it does add speed. why u gotta rip on the guy?</TD></TR></TABLE>
I wasn't ripping on him, i was just saying those things don't make power, because that is what the topic says
No doubt motor mounts, tires and weight reduction will help his car go faster, those are definitely good ideas.
Hites
Guest
Posts: n/a
Default Re: Cheap and easy power. (Turbo Rex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo Rex &raquo;</TD></TR><TR><TD CLASS="quote">How's this.... You get what you pay for.....</TD></TR></TABLE>
How's this.... **** off; youre not helping anyone.
Old Sep 8, 2003 | 02:33 PM
Hites
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DSeriesBKilla &raquo;</TD></TR><TR><TD CLASS="quote">try a ground strap set. it's not really all that cheap though but a lot of people i have talked to say that they can tell a difference in throttle response. :shrugs: just a thought.</TD></TR></TABLE>
somethin like this: http://cgi.ebay.com/ws/eBayISA...=1502 or http://cgi.ebay.com/ebaymotors...71249 dont flame me or any **** cause its ebay; im just a cheap *** .
Old Sep 8, 2003 | 02:38 PM
9200RPM's Avatar
I told you in a earlier post what I think...Damn your an ungreatful person...People are trying to help you and all you do is bitch and contredict what they say...If you want power out of your high milage LS add N2o, hurry up and blow it so you can ask us how to rebuild...Sounds to me like your a BDMF....
Old Sep 8, 2003 | 02:43 PM
Hites
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboB16aEG &raquo;</TD></TR><TR><TD CLASS="quote">I told you in a earlier post what I think...Damn your an ungreatful person...People are trying to help you and all you do is bitch and contredict what they say...If you want power out of your high milage LS add N2o, hurry up and blow it so you can ask us how to rebuild...Sounds to me like your a BDMF....</TD></TR></TABLE>
wtf is your problem? if you want to be a dick, go crawl up your mommas fat ***. sorry im not a ricer like you who worships the MaD tItE nAwZ y0! btw, youre bitching a LOT more than me so please; remove yourself, youre being a nuisance and taking up webspace that other may fill with helpful information.
Old Sep 8, 2003 | 02:47 PM
9200RPM's Avatar
Sounds like your a ricer......trying to make a 92 High milage LS fast....You probably don't even have a car....you got a liquorcycle.......Sounds your head is so far up your *** about your lil LS you have to use youself as a hat....Thats my 2 cents sounds like you need them for your buy a new car fund..biatch I don't have "nawz".....by the way...You wanna be cheap thats your way out...
Old Sep 8, 2003 | 02:55 PM
Hites
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboB16aEG &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like your a ricer......trying to make a 92 High milage LS fast....You probably don't even have a car....you got a liquorcycle.......Sounds your head is so far up your *** about your lil LS you have to use youself as a hat....Thats my 2 cents sounds like you need them for your buy a new car fund..biatch I don't have "nawz".....by the way...You wanna be cheap thats your way out...</TD></TR></TABLE>
again, wtf is your problem? this is the tech forum and you are not contributing a single useful thing, so why are you here? btw, when did i get a 92 ls? last time i checked i only had one teg. where did this 92 come from? did you give it to me? are trying to be an *** pal or something? what the hell is a "new car fund" and how do you buy one? oh wait, THERES NO SUCH THING AND IT MAKES NO SENSE! you dont buy funds you dumbass; and anybody who says "biatch" is either a ***, a ricer, or in your case, both. this isnt one of your homoerotic flame threads so get the **** out.
Old Sep 8, 2003 | 03:52 PM
Bodman's Avatar
both of you need to grow the **** up.
my answer would be that there is no really reliable CHEAP way to go...there just isn't. you want real power, you have to pay for it, it sucks I know, but thats how it is.
