Spherical bearing rear toe links
Old Sep 7, 2003 | 12:49 PM
euclid's Avatar
Default spherical bearing rear toe links?
i know that king makes a spherical rear camber link, i thought srr made a rear toe link with spherical bearing ends but i cant find them.
can anyone help me out? any other companies?
Old Sep 7, 2003 | 02:44 PM
essex's Avatar
Default Re: spherical bearing rear toe links? (euclid)
Do you drive your car on the street?
spherical bearing rear toe links will size up real quickly once dirt gets in them...impossible to avoid.
Old Sep 7, 2003 | 04:09 PM
euclid's Avatar
Default Re: spherical bearing rear toe links? (essex)
not for a street car, but for arguments sake i do not believe you are correct... jimfabs bars use sphereical bearings as well as teins pillowballs, i never hear complaints from people about siezing(knock on wood).
Old Sep 7, 2003 | 05:09 PM
Warren's Avatar
Wrong-Way Wang
Good spherical bearings won't seize, even on the street.
Wear however is a different issue.
Warren
Old Sep 7, 2003 | 05:10 PM
Extreme's Avatar
SRR do made a rear toe link with spherical bearing. They are optionally available
on three rear arms they sell (upper, lower, & toe.)
Modified by Extreme at 3:12 AM 9/8/2003
Old Sep 7, 2003 | 05:20 PM
Warren's Avatar
Wrong-Way Wang
Default Re: spherical bearing rear toe links? (Extreme)
Know a shop that carries them, or can get them in? With spherical bearings that is.
Warren
Old Sep 7, 2003 | 06:54 PM
Tweakmeister's Avatar
Default Re: spherical bearing rear toe links? (Warren)
I could probably get them.
Old Sep 7, 2003 | 09:25 PM
euclid's Avatar
Default Re: spherical bearing rear toe links? (Tweakmeister)
someone im me with a price on the toe and camber links if possible. is there a site that i can see some pics? thanks for the responses.
maxogsr
Jun 11, 2016 02:40 PM
TM_EM1
Suspension & Brakes
13
Sep 7, 2012 04:32 PM
Padronis
Jun 23, 2001 07:12 PM
