engine swap in EK question.
Hey guys, in the next few months i will be swapping a gsr or sir motor into my 2000 civic sedan. Can you guys make recommendations? im thinking gsr since it is a 4door...ive considered h22 but am leaning more towards the gsr for the drivability/realability factor since ive heard a lot of hings about this swap.
Also, would i want to convert to obd1 or stay with obd2? I hear that obd is a lot less hassle and is more friendly with bolt ons.
All info is welcome and appreciated.
Thanks all.
Modified by hondasport2000 at 6:42 PM 9/7/2003
Thanks all.
You'll probably be disappointed with the b16 and it's lack of torque. I'd stick with the 1.8 motor.
OBD 1 would also be a good choice. No secondary O2 and a few other things that might make the swap easier.
No, OBD 2 to OBD 1 is extremely easy.
It consists of buying a harness adapter and a chipped OBD 1 ecu. Plug them into your wiring harness and you're good to go. Takes less than 5 minutes.. and everything will be perfectly reliable.
You can buy any GSR motor from 96 to 01. If you use a Civic Si(SiR) wiring harness, you will make the swap 100x easier.
If you buy anything from pre-96, you're gonna run into problems when it comes to the distributor and injectors..
[QUOTE=Fowler]You'll probably be disappointed with the b16 and it's lack of torque. I'd stick with the 1.8 motor.
I agree. IMO its not worth $3000.00 just for another cam. You'll be happy with the 1.8.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JICEK9 »</TD></TR><TR><TD CLASS="quote">
I agree. IMO its not worth $3000.00 just for another cam. You'll be happy with the 1.8.</TD></TR></TABLE>
What???
What???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JICEK9 »</TD></TR><TR><TD CLASS="quote">[QUOTE=Fowler]You'll probably be disappointed with the b16 and it's lack of torque. I'd stick with the 1.8 motor.
LOL! So the 1.8 now has 3 cams??
Samuels
Apr 8, 2006 10:34 PM
cherroneballs
Jan 29, 2005 04:07 PM
integraXTC
Oct 27, 2004 06:17 PM
Petah
Jul 10, 2002 03:48 PM
