Installing SS Brake lines today, any tips?
Old Sep 7, 2003 | 08:40 AM
Bbasso's Avatar
Default Installing SS Brake lines today, any tips?
For the most part its simple, But I had to ask is there anything I should know that might not be obvious?
Old Sep 7, 2003 | 09:03 AM
Wai's Avatar
Wai
ProFunction/GT Motoring
Default Re: Installing SS Brake lines today, any tips? (Bbasso)
Rob, remember to use a flare wrench (10mm I think) for the brass nut to avoid stripping it.
Old Sep 7, 2003 | 09:15 AM
slackeR1366's Avatar
don't drink too much while the install
Old Sep 7, 2003 | 03:29 PM
rockwilda's Avatar
Default Re: Installing SS Brake lines today, any tips? (R1366)
are you installing the Goodridge SS?
if so, don't use their washers, they suck. just reuse the OEM ones..
Old Sep 7, 2003 | 03:42 PM
Back in Black's Avatar
Rather OG
Default Re: Installing SS Brake lines today, any tips? (rockwilda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rockwilda &raquo;</TD></TR><TR><TD CLASS="quote">if so, don't use their washers, they suck. just reuse the OEM ones..</TD></TR></TABLE>
True that.
Old Sep 7, 2003 | 03:58 PM
Black R's Avatar
25 Year Member
.....be gentle with the fittings. They don't need to be very tight - and if you **** up, you ruin them.
Old Sep 7, 2003 | 04:46 PM
sackdz's Avatar
Default Re: Installing SS Brake lines today, any tips? (Black R)
Torque the supplied banjoes 4 lbs. less then spec.
Old Sep 8, 2003 | 08:37 AM
Bbasso's Avatar
Default Re: Installing SS Brake lines today, any tips? (sackdz)
thanks for the tips.
I did all 4 with no problems, I just have to rebleed them- the pedal is not right yet.
And as for the drinking, I had none
and the flare 10mm, I also had none but the reg one worked just fine.
Hawk HPS front pads, are they more or less agressive then Axis Ultimates?
Yes they are Goodridge lines.
Old Sep 8, 2003 | 09:49 AM
Willard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">any tips?</TD></TR></TABLE>don't install them.
Old Sep 8, 2003 | 09:54 AM
Bbasso's Avatar
Default Re: Installing SS Brake lines today, any tips? (Willard)
WHY?
Old Sep 8, 2003 | 09:56 AM
Willard's Avatar
do you need them?
are you oe units cracked/old?
Old Sep 8, 2003 | 10:06 AM
Bbasso's Avatar
I got them so cheap I could not resist!
Old Sep 8, 2003 | 12:40 PM
Rather OG
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard &raquo;</TD></TR><TR><TD CLASS="quote">don't install them. </TD></TR></TABLE>
You know, you do have a point. Although I don't necessarily *mind* the feel of them, I liked the OEM feel better. I've never been able to get the pedal to feel as good as it did without the ss lines.
Old Sep 8, 2003 | 05:58 PM
Bbasso's Avatar
Default Re: Installing SS Brake lines today, any tips? (Jason Franza)
Jason, Could you explain that to be better?
Not really sure I follow.
Old Sep 8, 2003 | 06:09 PM
92TypeR's Avatar
FSAE
I agree with Jason. The OE pedal feel is much stiffer, which makes it easy for daily driving because there isn't as much pedal effort. However, I track my car frequently, and the SS lines greatly improve pedal modulation, and in my case, it places your foot in a better location for heel-toe action, as you have to dig deeper into the pedal to reach threshold. My $.02
As for the kit, I also have the Goodridge, but I used the OE washers and banjo bolts, as I ended up breaking one of the supplied banjo bolts.
Old Sep 8, 2003 | 06:17 PM
Bbasso's Avatar
Default Re: Installing SS Brake lines today, any tips? (92TypeR)
thanks for the small reveiw.
Old Sep 8, 2003 | 06:31 PM
SlapSmak's Avatar
I have heard this same feeling a couple of times, but one thing i did learn during my MANY brake bleedings after events of high brake use, bleed the brakes with the engine running, the ABS will pressurize correctly and you get kick *** pedal feel after you bleed them, much better than oe...
Old Sep 8, 2003 | 06:51 PM
Bbasso's Avatar
Default Re: Installing SS Brake lines today, any tips? (SlapSmak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlapSmak &raquo;</TD></TR><TR><TD CLASS="quote"> bleed the brakes with the engine running, the ABS will pressurize correctly and you get kick *** pedal feel after you bleed them, much better than oe...</TD></TR></TABLE>
Thats a great tip thanks!
blulude92
Dec 29, 2005 11:19 PM
unknown0001
13
Aug 28, 2005 05:41 AM
B2FiNiTY
32
Aug 6, 2003 02:21 PM
