IAB solenoid polarity obd1 vs obd2
Old Sep 7, 2003 | 08:20 AM
GruvyTune's Avatar
New User
Default IAB solenoid polarity obd1 vs obd2
anyone know for sure if there is a polarity issue between them? I now have an obd1 p72 running my 2001 prelude with a hondata. I have heard there is a polarity difference between them.
is this true?
Old Sep 7, 2003 | 04:56 PM
GruvyTune's Avatar
New User
Default Re: IAB solenoid polarity obd1 vs obd2 (GruvyTune)
ttt
Old Sep 7, 2003 | 07:50 PM
satan_srv's Avatar
I don't know what you mean....the only thing I can think of is the p72 will open them much later than the H22a..that's about all I know...
Old Sep 7, 2003 | 09:56 PM
Jago's Avatar
Default Re: IAB solenoid polarity obd1 vs obd2 (satan_srv)
the OBD1 is a switch to ground circuit and the OBD2 is a loas to ground circuit
Old Sep 8, 2003 | 03:54 AM
GruvyTune's Avatar
New User
Default Re: IAB solenoid polarity obd1 vs obd2 (Jago)
so does that mean one will open when the other will close the solenoid? do the wires have to be switched?
Old Sep 8, 2003 | 04:52 AM
satan_srv's Avatar
Well you can just open your hood and watch the diaphragm. When you start the car it should go under vacuum and close them...then rev to 5800 or something and they should open, see my post about IAB control on a p72 on an h22a...if I were you I would disconnect the plug and run them open all the time.
nicenlow1
Aug 3, 2008 04:13 PM
vi3tromanc3r
Apr 10, 2008 03:08 AM
kevpotts
Aug 2, 2007 07:32 AM
ENeRg3Tic
Apr 27, 2003 11:18 PM
Phat_GSR
Dec 15, 2002 05:31 PM
