JDM ITR front end Fog light question? swtich always illuminated
Old Sep 6, 2003 | 09:05 PM
capcon83's Avatar
Default JDM ITR front end Fog light question? swtich always illuminated
Yea i just got done wiring the fog lights for my jdm itr front end
the fog lights work real good but i was wondering about the button illumination its always lit up when fog light is on its on plus a green line when off still on but no green light.
i was wondering is that normal cause when i turn off the car set my alarlm its still illuminated with the amber light. and when my parking city lights are off and HID are off its still illuminated with the amber light?
thanks in advance
also i dont know how to spell
Old Sep 6, 2003 | 09:53 PM
canuck-mx6's Avatar
Default Re: JDM ITR front end Fog light question? swtich always illuminated (capcon83)
I think that the fog light pointing down is illuminated when the park/headlights are on, but the green light is only illuminated when the fogs are on. This is how mine is wired, but I could be wrong
Old Sep 6, 2003 | 10:46 PM
capcon83's Avatar
Default Re: JDM ITR front end Fog light question? swtich always illuminated (canuck-mx6)
ok see mine is always illuminated park/headlights are off but its still illuminated,
right now its still illuminated the switch is what im talking about
what did u wire your two red wires too from the switch ?
theres two red two black and one red/yellow wire
what did u put your two red ones and two black ones too?
thanks in advance
Modified by capcon83 at 10:29 PM 9/7/2003
Old Sep 7, 2003 | 01:31 PM
capcon83's Avatar
im having problems with the illumination on the button thats amber always being on it never turns off, thats my concern.
i used these diagrams
https://honda-tech.com/zerothread?id=105247
Modified by capcon83 at 10:45 PM 9/7/2003
Old Sep 7, 2003 | 02:07 PM
Denny's Avatar
the illumintation slot is one slot over to the right. they diagram is has the illumination in the wrong slot
Old Sep 7, 2003 | 02:23 PM
capcon83's Avatar
Default Re: JDM ITR front end Fog light question? swtich always illuminated (Denny)
so one slot over from the yellow wire to the right right?
Old Sep 7, 2003 | 07:08 PM
capcon83's Avatar
thanks alot it worked
Old Sep 7, 2003 | 07:09 PM
2000 Integra R #760's Avatar
thanks it worked for me too
Old May 12, 2004 | 12:57 AM
TurboTeG4's Avatar
the fog light wiring from the head light assembly is that in the blue wire harness?
Old May 12, 2004 | 08:53 AM
NWP4LIFE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Denny &raquo;</TD></TR><TR><TD CLASS="quote">the illumintation slot is one slot over to the right. they diagram is has the illumination in the wrong slot</TD></TR></TABLE>
yep that's right, I had the same problem until Denny helped me. Denny
That diagram Mike made needs a slight adjustment
Old May 14, 2004 | 12:02 PM
TurboTeG4's Avatar
So where is the plug for the fog lights at on the light assembly!!!!
HATE To start a new thread
Old May 14, 2004 | 02:13 PM
NWP4LIFE's Avatar
Default Re: JDM ITR front end Fog light question? swtich always illuminated (TurboTeG4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTeG4 &raquo;</TD></TR><TR><TD CLASS="quote">So where is the plug for the fog lights at on the light assembly!!!!
HATE To start a new thread</TD></TR></TABLE>
brown plug wrapped in blue tape, under the dash and in the engine bay by the driver side headlight.
Old May 14, 2004 | 02:42 PM
d8168055's Avatar
Default Re: JDM ITR front end Fog light question? swtich always illuminated (NWP4LIFE)
that brown plug, do u have to somehow connect the 2 fogs together (ie headlamp assembly)?
Old May 14, 2004 | 03:05 PM
TurboTeG4's Avatar
Default Re: JDM ITR front end Fog light question? swtich always illuminated (d8168055)
I meant the connector for the fog lights on the jdm headlight assembly
Old May 14, 2004 | 04:03 PM
NWP4LIFE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTeG4 &raquo;</TD></TR><TR><TD CLASS="quote">I meant the connector for the fog lights on the jdm headlight assembly </TD></TR></TABLE>there is no connector per se, one of the wires in the headlight harness is for the foglights, you tap into that.
ef9robert
Aug 3, 2007 12:06 PM
[Ennis_D]
Jan 11, 2005 06:50 AM
GSblueRacing
Sep 12, 2002 09:28 AM
GSblueRacing
Sep 12, 2002 09:15 AM
GSblueRacing
Sep 11, 2002 07:57 PM
