Bent Valves
Old Sep 6, 2003 | 08:17 PM
Chuji's Avatar
Default Bent Valves
I have to constantly do valve adjustments. I have overrevved this head about 5 times missing 1-2gear. Idle rmps are fine but I can feel a slight bumpyness that vibrates the car. A small amount of oil is on the spark plugs and blue smoke comes out at high rmps under WOT and during deacceleration. Bent valves? Is this the cause of a noisy valvetrain and the need to do constant valve adjustments?
Old Sep 6, 2003 | 09:27 PM
b19coupe's Avatar
Default Re: Bent Valves (Chuji)
It is certainly possible. Compression and leakdown should be your next order of business.
Old Sep 7, 2003 | 12:33 AM
MikeSarr_GSR's Avatar
Default Re: Bent Valves (b19coupe)
have your head looked at. chances are the LMAs are getting tired... as well as your vavlesprings. the likelyhood of bending valves without bottoming out the tach on a mechanical overrev is less... so you might just have a beat-*** valvetrain. either way... you should buy new, set all camgears to 0 for now and throw on a new timing belt if its time... y0
Old Sep 10, 2003 | 01:49 PM
BluePrintmfg.com's Avatar
Banned
it sounds like the LMA's needs to be replaced and the valves seals might need to be replaces also. I would take the head to someone that knows what they are doing and go from there. Good luck!
civicmitch
Apr 27, 2009 02:07 PM
loc_yaj
Apr 12, 2008 06:40 PM
curtisb16
Aug 10, 2007 10:56 AM
ironchef25
Jan 29, 2004 05:21 PM
Integra91LS
Feb 28, 2002 02:16 PM
