Question about the extra wiring involved swapping a b16 (99-00 si) into my ej6 (99 non-vtec dx)
Old Sep 6, 2003 | 07:30 PM
Smith Wise's Avatar
Default Question about the extra wiring involved swapping a b16 (99-00 si) into my ej6 (99 non-vtec dx)
Just like the titles states........
I'm trying to do some research, and I Have Searched H-T but I haven't been able to find any information about swapping a b16 or GSr into my ej6.
I'm pretty sure I'd have to re-wire for vtec, but what exactly is involved? I want to eventually swap. I figure I could do it over Christmas or possibly Spring break. I just want to allow myself sometime to deal with any "hic-ups" that may arise.
I have the stock engine, d16y7 w/o vtec. If I was to swap in a b16 with vtec what wiring would I have to do?
I'm trying to save a $900 installation charge from a shop. Any help is greatly appreciated.
SEARCH ****** will be ignored
Old Sep 8, 2003 | 05:08 PM
civic-4-ges's Avatar
Default Re: Question about the extra wiring involved swapping a b16 (Jswpstdoff)
You had to wire in both parts of the vtec selenoid, need to reqire the IACV into a 2-wire system. I also believe the CFK sensor is wired differently, maybe someone else can confirm this.
Old Sep 8, 2003 | 05:28 PM
B16b2b's Avatar
Default Re: Question about the extra wiring involved swapping a b16 (civic-4-ges)
why don't you just try to source a motor with a complete harness and ecu, and then eveyrthing will be plug and play. that'd be the easiest route, but may cost you a couple hundred extra dollars for the harness, but it'll be perfect, instead of stretching a d-series harness to make everything plug in.
Old Sep 8, 2003 | 06:12 PM
racecarpete's Avatar
Default Re: Question about the extra wiring involved swapping a b16 (B16b2b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16b2b &raquo;</TD></TR><TR><TD CLASS="quote">why don't you just try to source a motor with a complete harness and ecu, and then eveyrthing will be plug and play. that'd be the easiest route, but may cost you a couple hundred extra dollars for the harness, but it'll be perfect, instead of stretching a d-series harness to make everything plug in.</TD></TR></TABLE>
that would be because he is putting the swap in a 99 civic 1 peice haress as oppesed to a 5th gen 2 peice harness. It is much easier just to extend the necessary wires then to pull the entire harness.
courtesy katman.
Old Sep 8, 2003 | 06:14 PM
Smith Wise's Avatar
Default Re: Question about the extra wiring involved swapping a b16 (SilverCivic2k)
(1:37 AM 9/7/2003) salbaje: you will need to wire in knock sensor, vtec solenoid,vtec oilpressure. use your stock harness and modify that. it will make it easier
good advice
anything else.............
QUICKERSILV3R
Feb 5, 2006 01:38 PM
thalwr1
Aug 17, 2005 08:09 PM
JSPECHB
Apr 5, 2004 03:17 PM
RedCivik
May 9, 2002 01:29 PM
