3 Cylinder '90 RS ???
Old Sep 6, 2003 | 05:16 PM
TRH's Avatar
TRH
Default 3 Cylinder '90 RS ???
Hi, I'm new to the Honda / Acura world. I've been a european car guy forever.
I'm hitting the Honda and Acura forums as I just purchased a 90 Integra RS with 145K and a dead cylinder - previous owner says cylinders 1-2-3 have good compression but 4 has only 20 psi.
I'm hoping that its a top end thing......I think
Has anyone experienced a similar problem?
What kinda' special tools might I need for the timing belt, valves - special head bolt socket???
Is there any good manuals available and where can I get them?
Is this engine (B18A1 - I guess)widely available - is it used in other Honda models?
Thanks in advance fior your comments.
It's a cool car - if my daughter don't like it (doubtful), I'll gladly drive it over my trusty ol' Rocco
Old Sep 6, 2003 | 05:26 PM
mr.beeks's Avatar
Default Re: 3 Cylinder '90 RS ??? (TRH)
well it sound like the cylinder sleeve or piston needs to be replaced
so best bet is to get a newer engine wich run under $500 for
a b18b1 or a b18a1
and welcome to one of the fastest board around
will be glad to help
Old Sep 6, 2003 | 05:39 PM
TRH's Avatar
TRH
Default Re: 3 Cylinder '90 RS ??? (francisco flores)
under 500? - talk to me
The closest Acura dealer is about 125 miles away - the closest Honda dealer is 50 miles away......so parts aren't readily available here........heck the closest Walmart is 30 miles away
My brother has a few connections near Binghamton, NY but that's all I know.
Are these engines used in other Honda models?
Old Sep 6, 2003 | 06:08 PM
sugarloafpkwy's Avatar
You can get one for $500 just by checking the classified section of this board.
You could probably find just the block + pistons for much less. Check local engine importers for a japanese short block.
The B18a/B18b were only used on the integra, through 2000. Honda bored out the b18 to 2 liters for the Honda Crv, and this engine will bolt right in, as it's the same on the outside.
You can get a used engine real cheap for that car, and they are not to in demand, since most people want the 170hp B18C engine that came in the GS-r.
Anyways good luck replacing the engine. I've got a 92 LS with 200k on it and I love it.
mr.beeks's Avatar
couple of links for you
http://www.urbanracer.com classifieds
http://www.thepartstrader.com
http://www.thecarbuyersmarket.com
http://www.importbuilders.com
http://www.raceeng.com
http://www.bseries.net
most people sell them and buyer pays shipping...
Old Sep 6, 2003 | 06:28 PM
TRH's Avatar
TRH
So, you can interchange the B18 series without jumping through a bunch of hoops - computer / chip mods, electrical, etc????????????
Thanks for the comments/help!
Old Sep 6, 2003 | 06:29 PM
91tegrals's Avatar
yeah man welcome and on this site if you blink youll miss somthing..
Old Sep 6, 2003 | 06:41 PM
mr.beeks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TRH &raquo;</TD></TR><TR><TD CLASS="quote">So, you can interchange the B18 series without jumping through a bunch of hoops - computer / chip mods, electrical, etc????????????
Thanks for the comments/help!</TD></TR></TABLE>
blockwise easy swap
but when you swap the head thats when you have think about the engine management from
obd0 90-91
obd1 92-95
obd2 96-00
most of the time is just plug and play
and yeah dont blink cause you will miss some info here
Old Sep 6, 2003 | 07:28 PM
TRH's Avatar
TRH
I'm into Plug and Play - not interested in hacking the management stuff
If it's relatively straight forward then OK but..........
I've been surfing for an hour for these alleged $500 engines - ain't seen nothin' yet.
Thanks
Old Sep 6, 2003 | 08:41 PM
Loveless's Avatar
it's probably because you're looking at more than the engine. probably a ls engine with tranny and/or ecu which runs for about 1,000.
look around some more, you can even post up a wtb topic (want to buy)
Old Sep 11, 2003 | 06:17 PM
TRH's Avatar
TRH
Leak-down test indicates exhaust valve leaking
An intriguing thing though is the #4 spark plug was SOAKED with oil and the oil level is low - no smoke when running though -maybe a bad guide and valve?????
Compression cold - #1,2,3 - 200 # 4 - 20
So, I want to think that the bottom end is in pretty good shape.
I wonder what I might be getting into with freshening the head???????
Can you get reman heads somewhere?
R.S.AKIMOTO
Apr 4, 2007 02:00 PM
honda89
16
Feb 21, 2004 07:00 PM
Jared
Nov 24, 2002 03:19 PM
94cxHybrid
Feb 11, 2002 07:25 PM
