Spindle / Knuckles from all 92-95 Civics compatible?
Old Sep 6, 2003 | 12:45 PM
Bnjmn's Avatar
Default Spindle / Knuckles from all 92-95 Civics compatible?
I have a '92 CX and need new front knuckles. Will any 92-95 Civic knuckle interchange? Also- the ABS knuckles have larger wheel bearings, correct?
Old Sep 6, 2003 | 12:57 PM
Echo7847's Avatar
Default Re: Spindle / Knuckles from all 92-95 Civics compatible? (Bnjmn)
yes they interchange, not sure on the abs bearing question.
Why not just get bigger brakes? 94-95 Ex's came with 10.2" rotors, 94-01 integra's did also and came with a slightly larger caliper. You could grab all four sides and get a new brake booster/master cylinder and have much better braking.
Old Sep 6, 2003 | 01:01 PM
Bnjmn's Avatar
Default Re: Spindle / Knuckles from all 92-95 Civics compatible? (Echo7847)
Thanks...I already have a Wilwood front kit and the 11" Fastbrake/Integra rear setup. I need to get a spindle w/ABS sensors up front for a traction control setup as well as install the new hub that came with my DSS axles and it looks like an EX/ABS spindle will take care of it.
Thanks again
Ben
EJ6_PickUpStix
12
Jun 23, 2021 11:44 AM
tyb
Sep 3, 2013 02:05 AM
EJ2-Fluffy
Oct 11, 2010 10:23 AM
Hill4589
Mar 30, 2010 01:23 PM
JCracer723
Jul 6, 2008 05:10 PM
