Where is the 5th gen accord fuel pump located? in tank?
Old Sep 6, 2003 | 12:43 PM
HybridAccord's Avatar
Default Where is the 5th gen accord fuel pump located? in tank?
i just got a h22 motor swap into my 95 accord, i need more fuel and decided to put a fuel pump in. it is not in the trunk or behind the back seat like most hondas. but am not sure if it is in the gas tank. please let me know if it is in the tank so i can drop it out or is it located somewhere else.
please email me at hybrid95accord@aol.com if you do know
thanks
Old Sep 6, 2003 | 12:54 PM
whoa its len 2's Avatar
Fuel pump is in the gas tank. With a mildly modded h22 I'd look into a fuel pressure regulator before the fuel pump.
Old Sep 6, 2003 | 01:04 PM
Default Re: (whoaitslen2)
i have a fuel press. reg and its turned up.. but my car is still running lean .. somehow it isnt getting enough fuel .. im thinking it could be my filter.. but i am going to change my fuelp pump as well.. for other mods.. so it is in the gas tank and i have to drop the tank out to change the pump?
Old Sep 6, 2003 | 03:57 PM
Stew Pidasso's Avatar
Default Re: (HybridAccord)
Yes, it's in the tank and you do have to drop it...
Old Sep 6, 2003 | 06:16 PM
iam7head's Avatar
Default Re: (Stew Pidasso)
just take off the two beam that supporting the tank and you have to drop the tank some how, it's alot of work.
try to use up as much gas as possilble before installation
Old Sep 6, 2003 | 08:35 PM
MAX HARDCORE's Avatar
Default Re: (iam7head)
**** it man, i would just rather just pay some one to do it. my friend helped me
out w/ mine on a lift.. never again....it a mother ******
Old Sep 7, 2003 | 04:36 PM
brads94accord's Avatar
did you look under the trunk liner in your trunk? i believe you can take it out through the inside of the car. all the wiring harnesses plug in under there. its right by the bottom of the backseat.
Old Sep 7, 2003 | 04:45 PM
iam7head's Avatar
Default Re: (brads94accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brads94accord &raquo;</TD></TR><TR><TD CLASS="quote">did you look under the trunk liner in your trunk? i believe you can take it out through the inside of the car. all the wiring harnesses plug in under there. its right by the bottom of the backseat.</TD></TR></TABLE>
Nope, not for 5th gen
Old Sep 7, 2003 | 10:51 PM
accordfreak's Avatar
Default Re: Where is the 5th gen accord fuel pump located? in tank? (HybridAccord)
search for the threads
here's mine https://honda-tech.com/zerothread?id=548287
cwhabegger
Nov 8, 2009 02:13 PM
jerry454
Apr 21, 2008 10:35 PM
mark2oo3
May 31, 2006 09:55 AM
kaoss_11
11
Dec 9, 2004 08:29 PM
