NEEEEED HELP
my friend has a b16 and i just changed the cams to 98 itr cams and we changed the timing belt also the car runs like **** but it idles fine very wierd. i checked the valves, timing is all tdc, grounds are good, and distributer timing is correct, what else could i possibly do i also too hose off of the fpr to raise fuel presure and still runs shitty. need help badly
Without the vacuum line to the FPR it won't be changing according to Vacuum, hook it back and see what happens... The extra fuel should be there under full throttle, close to what you'd be at now without the vacuum line. Go and get a B&M regulator, and gauge, this is a super simple mod that can help a lot in dialing in slight fuel changes...
Good luck...
Jung
Good luck...
Jung
lsvtec_hatchback
Mar 25, 2009 08:33 PM
killerpenguin21
Aug 7, 2008 11:16 AM
blowme
May 17, 2005 04:48 PM
