overheating problem
Old Sep 6, 2003 | 07:57 AM
dash80's Avatar
Default overheating problem
i have a 93 civic dx that is overheating intermittently. sometimes it will not overheat at all and other times it will overheat when i am at a red light. sometimes the coolant level is low and there is no coolant in the overflow tank, then when i put water in and drive for a while i check the level and the overflow tank is full. any ideas?
Old Sep 6, 2003 | 11:02 AM
5thgencivic's Avatar
Default Re: overheating problem (dash80)
Do a leakdown test to see if it's a bad headgasket. Could be a bad thermostat, water pump or head gasket.
Old Sep 6, 2003 | 07:34 PM
Mohudsolo's Avatar
Default Re: overheating problem (5thgencivic)
Fan working? If yes, I would also suspect the head gasket.
makahana187
Jul 11, 2009 06:08 AM
jdmsohc2nr
Dec 6, 2007 06:04 PM
turbols99
Feb 5, 2007 07:28 PM
Nocturnal
Dec 6, 2005 11:59 AM
veejay
Jun 30, 2001 09:02 AM
