FUEL PRESURE INFORMATION
Old Sep 5, 2003 | 05:18 PM
B HATCH's Avatar
Default FUEL PRESURE INFORMATION
OK i have a b18c1 in my DX civic....right now i have the stock fuel pump and i only have good performance at a full tank of gas. I suspect the fuel pump.
After looking into things i relize that the stock civi has a fuel pressure of 28 to 36 psi and the b16a2 has 30 to 37 and the b18c (1 or 5) is 38 to 46. I have a 2000 Civic Si Fuel pump that i got (i was told it was a GSR!).
What am i lookin at here, how does a fuel presure regulator and with the correct ENu should not the system still run at the right PSI, but run at less LPH correct ???
So basicaly i have a b16a2 fuel pump i can install but will not be correct since i need more PSI...and there for will not have enought LPH when the ECU tries to make the required PSI with that fuel pump....or am i off my rocker here?
Old Sep 5, 2003 | 05:51 PM
skribblah's Avatar
Default Re: FUEL PRESURE INFORMATION (B HATCH)
get a walterburo ( i dont know how to spell it) 255lph fuel pump = $80
get a FPR = $?
you should be set.
Old Sep 5, 2003 | 05:53 PM
DragII's Avatar
25 Year Member
fuel pressure is handled by the fpr. gsr, and type r have differnant ones than other b series motors. the rest is the same.
Old Sep 5, 2003 | 06:07 PM
civicgsr93's Avatar
Default Re: FUEL PRESURE INFORMATION (skribblah)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skribblah &raquo;</TD></TR><TR><TD CLASS="quote">
get a FPR = $?
you should be set.</TD></TR></TABLE>
Well said!!!, Holley makes a good 255lph fuel pump, noisy do.
Jonathan
Old Sep 5, 2003 | 06:21 PM
JaeOne3345's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skribblah &raquo;</TD></TR><TR><TD CLASS="quote"> get a walterburo ( i dont know how to spell it) .</TD></TR></TABLE>
LOL walbro.
Old Sep 5, 2003 | 06:22 PM
B HATCH's Avatar
Default Re: FUEL PRESURE INFORMATION (JaeOne3345)
SO will a b16a2 fuel pump (which i have in my hand right now) work if i use it with a stock GSR? or will i still be missing the boat.
Old Sep 5, 2003 | 06:31 PM
tvrsir's Avatar
should work no problem
all b series have the same flow except integra ls
Old Sep 5, 2003 | 06:33 PM
intezn's Avatar
Default Re: FUEL PRESURE INFORMATION (tvrsir)
what about integra ls then?
i have a b18b in my eg, with stock eg fuel pump
Old Sep 5, 2003 | 07:04 PM
drvfast's Avatar
lol
Old Sep 6, 2003 | 12:22 AM
aw1234dude's Avatar
Default Re: FUEL PRESURE INFORMATION (drvfast)
I though all d series and LS motors use 79 LPH pumps and all B series ones use the 139LPH pumps. So your b16 pump will be the same as a GSR one.
rth_1984
Aug 3, 2011 05:04 AM
GS-R Civic
Dec 2, 2005 06:57 PM
iNetForce
Nov 13, 2005 08:27 PM
Louie_EM1
May 15, 2004 01:12 PM
