EG speed Odometer not working. Just suddenly stopped..help..
The dash lights are on, the RPM works. The mileage counter doesnt nor does the trip counter. I havent taken my dash apart or anything, I just got in and started it, pulled off and noticed it wasn't working. It was working earlier. If someone knows what fuse it is to check that'd help because I searched and couldnt find it. Unfortunately the fuse box lid in my car isn't there, dont even know where it went, just noticed it was gone now. What else could it be if it's not the fuse.
wheel speed sensor.....dunno where it is...never ha dproblems with it myself..but it sounds like your wheel speed sensor is either broken or dislodged...
My speedo (as well as odo) would intermitantly drop to zero while rolling down the street. I wanted to swap to a jdm cluster anyway, so I figured it was a sign from above.
Uhmm.. that last post helped me not. But thanks for the info.
Okay now I just realized my cruise control doesn't work. Earlier on today, I did use my cruise control and it worked fine riding down this long *** empty street. Now the light ont he dash wont come on but the button light will.
sometimes there are corrosion on the connections take it out clean it and plug it back up
i meant the speed sensor okay. e one right below the throttle body. on top of the trans.
it is most likely your VSS its located on the top of the tranny. you can get them for about 50 bucks i think (used)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dream »</TD></TR><TR><TD CLASS="quote"> Is it easy to connect.</TD></TR></TABLE>
it is extremly easy. just unplug the harness, unbolt sensor, pull it out and install the new one.
T Rick
Jul 26, 2008 05:33 PM
