Wiring diagram for 97 dx HB if NE1 needs it
I found one doing a search but it was for the EG so did a little search w/ some friends that do installs and this is it. HTH anyone that needs it.
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|white |+ |ignition harness |
| STARTER|black/white |+ |ignition harness |
| IGNITION|black/yellow |+ |ignition harness |
| SECOND IGNITION|yellow |+ |ignition harness |
| ACCESSORY|white/black |+ |ignition harness |
| PARKING LIGHTS +|red/black | |dkp or fuse box or *2 |
| PARKING LIGHTS -| | | |
| HEADLIGHTS|red/wht(L)red/blu(H)|+ |column or fuse box |
| DOOR TRIGGER|green/black |- |drivers 'A' pillar |
| TRUNK/HATCH PIN|blue/black |- |dkp or fuse box*3 |
| HOOD PIN| | | |
|TRNK/HTCH RELEASE| | | |
| FCTRY ALARM ARM| | | |
|FCTRY ALRM DISARM| | | |
| TACHOMETER|blue | |test connector*1 |
| BRAKE WIRE|green/white |+ |brake switch |
| HORN TRIGGER|gray or blue |- |steering column |
| WIPERS|blue and blue/yellow|- |column |
| LF WINDOW UP/DN| | | |
| RF WINDOW UP/DN| | | |
| LR WINDOW UP/DN| | | |
| RR WINDOW UP/DN| | | |
Notes:
*1 Drivers side fire wall. *2 Male blade connector at fuse box. *3 Two door hatch back does not have trunk pin.
| HOOD PIN| | | |
Notes:
TwoFaced
Dec 16, 2010 05:34 PM
