93 VX Hatch Questions
I am going to install a D16Z6 And was wondering the following
1. Exhaust which ones can I use? I know I can use the Stock Si exhaust but can I use a DelSlow exhaust also?
2. Intake Air Box is the same? also what car can i use for the intake piping from the box to the intake mainfold.
3. Now regarding the ecu I am suppose to get a P28 ECU and chip it? or can I run my current Stock ECU?
Now if there is something else I am forgetting please let me know.. I want to get everything together before I swap the motor out.
thanks in advance
thanks in advance
1. Del Slow exhaust bends a little differently, won't be an exact fit and may not fit at all.
2. Air box should be the same if I'm correct, you should use an intake tube from a d16z6 since yours will be too small I believe.
3. P28 came with the single cam VTEC motors, so you will use that ECU and won't need to chip it. Since you have a VX there may be a possibility of using yours (don't qoute me on this, since I wouldn't do it) but the P28 is designed to run that engine- so get one for it.
Chicano
Mar 24, 2007 10:07 PM
HomeBuilt
Sep 22, 2004 09:25 PM
