DA rear disc brake conversion?
Old Sep 5, 2003 | 02:13 PM
untitled's Avatar
Default DA rear disc brake conversion?
both of these rear suspensions are the same right. so wouldnt it just bolt right up? i have a parts DA sitting and a 89 Si so that has the gay rear disc. help!!
Old Sep 5, 2003 | 02:21 PM
bryant's Avatar
Default Re: DA rear disc brake conversion? (lstegwithvtec)
Uhh, what?
Old Sep 5, 2003 | 02:23 PM
untitled's Avatar
Default Re: DA rear disc brake conversion? (Bryant)
DA 90-93 integra rear disc brake conversion. nm. i got everything i needed to know off of fourth generationcivic.com thanx tho.
Old Sep 5, 2003 | 02:24 PM
raene's Avatar
I don't quite understand.. your '89 has the gay rear disc? Do you mean gay rear drum?
Yes, it will bolt up. You'll have to route the e-brake cables "creatively" however. I'd recommend getting the DA front conversion also and using the 'Teg M/C and booster and prop valve so as not to throw the brake balance off. These things are carefully tuned.
*edit* Damn j00, too fast.
Old Sep 5, 2003 | 02:35 PM
untitled's Avatar
Default Re: DA rear disc brake conversion? (raene)
yea my bad. gay rear drum.
mynameizstitch
10
Dec 13, 2009 03:06 PM
eg8ynot
Nov 6, 2008 04:43 PM
crunchy_taco
Apr 25, 2007 11:01 PM
wongf22b2
Apr 26, 2004 02:55 PM
