REVlimit on B18B
Old Sep 5, 2003 | 01:49 PM
shawn_crx's Avatar
Default REVlimit on B18B
Do anybody know the Rev limit on B18B if built the head and bottum?
Old Sep 5, 2003 | 02:12 PM
Kamin's Avatar
Default Re: REVlimit on B18B (shawn_crx)
it depends on what you use to build it
Old Sep 5, 2003 | 02:18 PM
shawn_crx's Avatar
Default Re: REVlimit on B18B (Kamin)
Going with crower cams Turbo (springs, retainer, and valve)
Je Piston 8.5:1 std
Eagle rod I beam
don't know which crankshaft yet.
Old Sep 5, 2003 | 02:27 PM
fivespeedintegra's Avatar
the stock crank is pretty damn strong.
forged i believe.
Old Sep 5, 2003 | 03:10 PM
12secB18acivic's Avatar
i use to rev my b18b to 8500 with no problem and i only had shot peen rods and dual valve springs.
Old Sep 5, 2003 | 09:32 PM
allmotorEG-SI's Avatar
Default Re: REVlimit on B18B (12secB18acivic)
I get shut down at 7100. Stupid fuel cut off!
But than again I have a stock engine. So thats probably a good thing.
Old Sep 5, 2003 | 09:51 PM
dunkd's Avatar
LS blocks dont have an oil line running into the block that gsr's and type r's have so that is why reving SAFELY is limited... for example when ppl build LS/VTEC an extra oil line is put in.
Old Sep 6, 2003 | 12:18 AM
mmuller's Avatar
Mad Scientist
Default Re: (dunkd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd &raquo;</TD></TR><TR><TD CLASS="quote">LS blocks dont have an oil line running into the block that gsr's and type r's have so that is why reving SAFELY is limited... for example when ppl build LS/VTEC an extra oil line is put in.</TD></TR></TABLE>
??? no, the extra oil line added is for vtec, not to rev higher
Im assuming that your getting the 62402T's so i would say 7500
Old Sep 6, 2003 | 07:38 AM
MrTodd's Avatar
Default Re: (mmuller)
About the only thing you can do in the bottom end to help rev's would be adding an aftermarket girdle... The crank is solid.
Old Sep 6, 2003 | 08:10 AM
notstock93's Avatar
Default Re: (MrTodd)
WIth some ARP rod bolts, the B18B can take one hell of a beating. 7500 with no problem with ARP rod bolts and a better valvetrain. I would think twice about going to 8k, though.
Old Sep 6, 2003 | 09:01 AM
T4eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrTodd &raquo;</TD></TR><TR><TD CLASS="quote">About the only thing you can do in the bottom end to help rev's would be adding an aftermarket girdle... The crank is solid.</TD></TR></TABLE>
honda cranks are overkill. get some good rods and a girdle and you will be set.
Old Sep 6, 2003 | 10:46 AM
notstock93's Avatar
Default Re: (BlueHatch00)
Do NOT forget ARP rod bolts. I wouldnt even worry about upraged rods unless your going higher than 7,600 or so, or your doing forced induction. Otherwise, just have then shotpeened and balanced (cheap!)
Old Sep 7, 2003 | 10:27 AM
shawn_crx's Avatar
Default Re: (notstock93)
what is a girdle?
blaccrex
Nov 28, 2014 11:42 AM
mars-EF-LS
Jun 23, 2007 12:12 PM
greeneg2.0
Oct 16, 2006 01:20 PM
methodz55
13
Apr 11, 2006 07:15 AM
boostinls
Oct 23, 2002 08:09 PM
