HELP: My car won't start! :(
Hey yesterday it was running perfectly, went out this morning and the engine turns but it won't start. I'm think it is something with the fuel system or ignition. Can anyone help me?
I sorta don't have money to have a shop come pick it up! I just can't imagine what could've gone wrong between now and 10 hours ago.
EDIT: Sorry, its a 1994 Accord LX F22b2
I sorta don't have money to have a shop come pick it up! I just can't imagine what could've gone wrong between now and 10 hours ago.EDIT: Sorry, its a 1994 Accord LX F22b2
Bah, I took the fuel line off the rail, and started it, no fuel was coming out, so now my conclusion its the main relay or the pump. Thanks anyways everyone.
Or the pump itself. If you can access the wiring for the fuel pump, check for available voltage to the pump. If it's there, then the pump is bad.
The main relay you should be able to hear it 'click' when you first turn the key on, then click again about 2-3 seconds later after the pump primes, if it's working correctly. If you don't hear any click (it's kinda faint, so make sure it's quiet around), then the main relay is likely the culprit
You did check the fuses already, right? Both under dash and under hood
ej84dr
Jun 16, 2010 05:20 AM
juanchoenuncrx
Aug 29, 2007 07:59 AM
bogus_ek
Jun 4, 2004 10:18 AM
