ok to mount battery on its side ?
Old Sep 5, 2003 | 01:26 PM
Code Blue's Avatar
Default ok to mount battery on its side ?
im doing this to clear up room under the hood, can the oem acura battery handle being on its side or will it leak?
Old Sep 5, 2003 | 06:06 PM
Code Blue's Avatar
Default Re: ok to mount battery on its side ? (Code Blue)
up
Old Sep 5, 2003 | 06:13 PM
D-Man's Avatar
it will leak and may short out the plates inside it cause its a wet cell battery...buy a dry cell battery like an Optima or Holley then you can mount it anyway you want
Old Sep 5, 2003 | 06:14 PM
Code Blue's Avatar
Default Re: ok to mount battery on its side ? (D-Man)
thank you sure, that is exactly what i needed to hear, any good places to get one relatively inexpensive?
Old Sep 5, 2003 | 06:16 PM
Prod's Avatar
http://www.batterymart.com
look at odyssey batterys, they are light as ****...I just picked up one for my audi, 22lbs - 105 bucks
Old Sep 5, 2003 | 06:17 PM
Code Blue's Avatar
Default Re: ok to mount battery on its side ? (Prod)
would it work with a medium sized audio system
Old Sep 5, 2003 | 06:34 PM
Prod's Avatar
Depends on the reserve capacity your looking for...basically more reserve capacity means a bigger battery which means heavier. I beleive if you look at the odyssey batterys you'll find one that will meet your needs and still be lighter than stock.
Give these guys a call they are the authorized dealer in NJ - The guy that works there is really knowledgable about the batterys and what they can and cannot do, he can also recommend a size for you.
Sure-Way Electric Sales, Inc. North Caldwell NJ 800-223-4456
http://www.odysseyfactory.com/ <-manufacturers site
Old Sep 5, 2003 | 07:08 PM
Code Blue's Avatar
alright thanks man.
m R g S r
Welding / Fabrication
13
Jun 29, 2009 05:04 AM
acmoc
27
Jan 7, 2009 03:26 AM
spontaneous ep3
16
Sep 7, 2004 09:04 PM
