need help taking axle off of intermediate shaft
Old Aug 18, 2001 | 06:46 PM
Lei Siew Long's Avatar
Default need help taking axle off of intermediate shaft
i took off the intermediate shaft and axle off of the tranny as one piece. so, i want to take off the axle from the intermediate shaft off of the vehicle. you might be wondering why would i want to do this, well, i want to do this because i tried to hammer the axle off of the intermediate shaft while it was on the car for about three continuous days with no luck.
so, i want to do this because i want to take the axle off to replace the set ring because i'm afraid all that hammering might have loosened the axle a bit. this is just to avoid from any sort of catastrophe or trouble while i race and to avoid from doing the same job twice.
any help is appreciated. it is pretty hard since the intermediate shaft is no longer bolted down. thanks in advance. as for the ones that have been following me on this project, i know, i know, this **** is taking a long *** time. especially since i can only work on the car after work (2 jobs)
Old Aug 18, 2001 | 06:54 PM
BreakStuff's Avatar
New User
Default Re: need help taking axle off of intermediate shaft (boostedeg6)
I ran into the same situation a couple months ago replacing cv boots..
To make a long story short.. I never got that axle out of the intermediate shaft..
As long as you havent been hammerin' it sensless, I wouldnt worry about any damage.. Check the axle for any "free play"... If it seems ok, then go with it..
Old Aug 19, 2001 | 12:19 AM
Default Re: need help taking axle off of intermediate shaft (BreakStuff)
is there supposed to be any play between the axle and the intermediate shaft? as of right now, there is some play between the two. it shifts back and forth when i push it towards the intermediate shaft and towards the opposite side as well.
oh yeah, thanks for the reply
Old Aug 16, 2003 | 05:30 PM
krshultz's Avatar
Default Re: need help taking axle off of intermediate shaft (Hatch4urSnatch)
Bringing an old one out of the archives...
In answer to the play question, yes, there will be a little bit.
Personally I'm wondering if anyone has had luck doing this job. I've got an intermediate shaft, off the car, with a trashed inner joint attached to it. No amount of pounding the joint (which is busted so damage doesn't much matter) with a BFH has gotten it out.
It'd really be nice to get this thing out of there since I need the inner joint to do my warranty claim on the axle that lasted one and a half days on track. Anyone got suggestions, or is the whole assembly trash now?
Old Aug 16, 2003 | 07:33 PM
HONDADNA's Avatar
you need to use a brass hammer and place the axle on a vise if possible. Also, you should spray some rust off lube if rusted or WD40. But, with a brass hammer you hammer the axle without damaged; for, brass hammer's are a soft metal and it some likely to break first then the axle itself.
But here's how to do it - most likely the c-clip is wedge during the hammering. so, tap on the outter shaft to release the c-clip. also spray some lube before you tap on the outter shaft. then hammer the inboard joint hard - remember use a brass hammer so no damage would occur to the axle.
Old Aug 16, 2003 | 07:55 PM
krshultz's Avatar
Default Re: need help taking axle off of intermediate shaft (HONDADNA)
You kick *** HONDADNA, I'll try it
Old Aug 17, 2003 | 12:58 AM
salbaje's Avatar
i usually use a socket big enough to get wedged in between and hammer that in and it will seperate
Old Aug 17, 2003 | 03:21 PM
smokey2.0's Avatar
Default Re: need help taking axle off of intermediate shaft (salbaje)
the last time that happened to me, the driver side axle was bad. since that axle had no grease in it, all that heat went to the intermediate shaft and fused the axle and the intermediate shaft together. it took me a 1/2 hour of solid hammer work, to separate the two. now when i work on the tranny, if i notice that that axle doesn't wanna come out of the intermediate shaft i will replace it!
Hoppa
Dec 5, 2006 08:51 AM
jacoop86
Aug 11, 2006 04:07 PM
huepowered
Mar 27, 2006 12:33 PM
vha27
Nov 17, 2003 07:27 PM
