My car is over heating ??????
Old Aug 18, 2001 | 06:28 PM
biggtopscott's Avatar
New User
Default My car is over heating ??????
my car is over heating , my cooling fan stopped workin ? before i bought a new motor for it , i straight wired it to my battery and it worked ? so what could the problem be ??? the fuse to it is fine ?
Old Aug 18, 2001 | 06:36 PM
BreakStuff's Avatar
New User
Default Re: My car is over heating ?????? (biggtopscott)
Year/Make/Model Car?
Did you install the same motor?
assuming if your cooling fan isn't working, then see this post... https://honda-tech.com/zerothread?id=56489
[Modified by BreakStuff, 3:39 AM 8/19/2001]
Old Aug 18, 2001 | 06:39 PM
New User
Default Re: My car is over heating ?????? (BreakStuff)
yeah i straight wired it , to make sure it was bad , it wasnt bad i dunno what the prob is the fuse to it is fine ya think it is the relay ??? some one told me it was the temp sensor but on my car when you start it the cooling fan always comes on .
Old Aug 18, 2001 | 06:42 PM
BreakStuff's Avatar
New User
This info is needed to know if the car has a seperate cooling fan "timer" unit..
If it doesn't have one, it should be an easy fix...
If it does have one, it will prolly be a nightmare!
Old Aug 18, 2001 | 06:43 PM
New User
thanks dude !
Old Aug 18, 2001 | 06:44 PM
New User
95 civic ex vtec d16z
Old Aug 18, 2001 | 06:46 PM
DragII's Avatar
25 Year Member
Awesome link
Old Aug 18, 2001 | 07:05 PM
BreakStuff's Avatar
New User
Default Re: My car is over heating ?????? (DragIIcivic)
another issue that I have recently discovered.. cars that do use a timer unit have the switch on the positive circuit, thus meaning.. power is NOT applied to the fan at all times.. power is applied to the relay when the ignition is in the "on" position, and waits for a response from the timer unit to activate the relay to turn on the cooling fan..
mark2583
Jan 20, 2010 10:46 AM
immalooser
Apr 8, 2007 01:00 PM
civiconfire
Sep 16, 2006 09:19 AM
s2kkk
Aug 29, 2004 10:35 PM
