E-Brake light problem....
Old Sep 5, 2003 | 10:40 AM
Grocery Getter's Avatar
Default E-Brake light problem....
I have searched and everyone elses problems are similar but not the same....
My problem is the e-brake light is always on from the min. i turn the car untill i turn it off. when the e-brake is up the light just gets brighter, when the e-brake is down the light is not as bright...
anyone have an idea why id would do this?
thanks in advance,
-tim
Old Sep 5, 2003 | 10:55 AM
Default Re: E-Brake light problem.... (Grocery Getter)
any help?
Old Sep 5, 2003 | 02:31 PM
Chiovnidca's Avatar
Is your brake fluid low?
Old Sep 5, 2003 | 07:09 PM
b19coupe's Avatar
Default Re: E-Brake light problem.... (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">Is your brake fluid low?</TD></TR></TABLE>
What he said. Brake fluid level would be the first thing to check.
Old Sep 6, 2003 | 11:02 AM
Default Re: E-Brake light problem.... (b19coupe)
fluid level is fine, im changing the caps today, because i read somewhere that, the floater switch can go bad, so ill check that out and check the actuall leaver switch.
ill get back to this thread in a bit, any other help would be great
thanks,
-tim
Old Sep 6, 2003 | 12:59 PM
b19coupe's Avatar
Yeah, seen a few bad master cylinder cap switches.
Old Sep 6, 2003 | 06:29 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grocery Getter &raquo;</TD></TR><TR><TD CLASS="quote">fluid level is fine, im changing the caps today, because i read somewhere that, the floater switch can go bad, so ill check that out and check the actuall leaver switch.
thanks,
-tim</TD></TR></TABLE>
That's easy to check. Just unplug it and connect the wires together to see if the light goes out.
Old Sep 6, 2003 | 07:29 PM
BoostedAcura's Avatar
There is a good chance the wire just came unhooked from the ebrake its self. Try giving that a check
Old Sep 6, 2003 | 11:03 PM
Default Re: E-Brake light problem.... (BoostedAcura)
thanks for all the help it just happened to be the cap, it was bad.
changed it and its back to normal.
thanks everyone
-tim
Old Jan 19, 2004 | 10:07 PM
speedaholic92's Avatar
i know you can change the caps on stock master cylinders, what about aftermaket cylinders??? i just put a new one today and the light stays on?? do they sell caps for non oem??
Old Jan 20, 2004 | 10:53 AM
doublejz's Avatar
Default Re: E-Brake light problem.... (speedaholic92)
short, ebrake switch bad, low fluid my guesses
LunchboxZT
Sep 8, 2006 01:22 PM
grandmasterflash
Dec 28, 2005 05:55 AM
sullycrx
Nov 16, 2005 09:48 PM
Project91CRX
14
Apr 26, 2004 03:47 PM
ITR #1202
Jul 8, 2003 11:00 AM
