Quick Clutch question!!!
just about to change my clutch.....had my flywheel resurfaced 4k ago and changing to a used stock clutch......had ACT thats acting up....
question....DO I NEED TO RESURFACE THE FLYWHEEL AGAIN
If you feel anything other than a smooth surface on your flywheel, the answer is yes.
You shouldn't have to unless you spent a lot of time feathering the clutch and generating too much heat.
