Attn: Those with Spoon Springs
"Haters Gonna Hate"
Those of you who are using the Spoon progressives, how long did your stock shocks last (I'm trying to figure out how long my AGX's will last) and what camber readings did you get after you had an alignment? From what I understand the springs were intended to be used with the stock dampers. Also do you get excessive inner threadwear? TIA
not sure about the camber settings or shock life, but the treadwear is dependent on tire size, brand, inflation, etc, and also camber/toe settings can greatly affect tire wear as well so it might be hard to gauge how your particular tires will be affected.
