Valve Adjustment HELP!!!! PLEASE@!!!!!!!!!!!
Old Aug 18, 2001 | 05:04 PM
Darren804's Avatar
Default Valve Adjustment HELP!!!! PLEASE@!!!!!!!!!!!
Hi everyone.. i'm doing my first valve adjustment.. got a problem though.. when I was done with it I found out I was using the .015 mm-.021mm instead of the .15-.21mm feeler guages??? so now the engine sounds loud as heck... turned it off...
Does anyone know it's a misprint in the helm manual??? it it really the .15-.21mm???
one more thing.. for each bolt... say on first cylinder.. there are like 4 nuts you can adjust.. 2 on intake and 2 on exhaust... so i'm suppose to insert the feeler guage right on top of the bolt right...????..... not sure how to explain.. ok,. I see the cam... there are like 3 sections...right on top of each nut is a section of the cam... and then there is the middle section where there isn't a nut..??? I'm suppose to adjust the 2 sides of the cam right?? not the middle???? yes it's my frist time... hope someone can help me.. I gotta finish this quick...!!!!
and is it ok that I stick in the feeler guage on the side where the nut is or behind it..what I did was adjust the nut.. stick the guage in from the nut side...if it was too loose then I readjust and stick in the guage again...??? Thanks all!!!
This is for a 98 GSR...!!!
Old Aug 18, 2001 | 05:14 PM
Darren804's Avatar
Default Re: Valve Adjustment HELP!!!! PLEASE@!!!!!!!!!!! (Darren804)
anyone???
Old Aug 18, 2001 | 05:17 PM
Darren804's Avatar
anyone?
Old Aug 18, 2001 | 06:14 PM
BUSAFREAK's Avatar
Darren, your first problem is that "you have to do this quick". You gotta take your time and do it right. I assume you dont have the adjustment tool that has the flat head screwdriver, so that alone tells me its gonna take a long time. Use the longer angled feeler gauges. You will need 2 different sizes 1 intake and 1 for exhaust. You will slide the gauge on the side that the bolt is on. There should be a spec sticker somewhere on the engine compartment that tells you the specs for valve lash. +/- is the acceptable tolarence for gauge sizes.
Old Aug 18, 2001 | 08:08 PM
Darren804's Avatar
Default Re: Valve Adjustment HELP!!!! PLEASE@!!!!!!!!!!! (ITR1162)
thanks guys... I finally finished it... got the right feeler guage from the auto shop... I was using the .015mm guage when it was suppose to be .15mm... ooo I bought the snap on tool so adjusting was easy... finished it all in 1 hour... I used someones advice... for the intake... fit in the .006 until it's snug... and then make sure the .007 in guage won't fit in... is that a good approach.. I'm not sure if the car is quieter... I still hear a faint tapping noise.. but that is normal right???
Old Aug 18, 2001 | 08:30 PM
mojoGSR92's Avatar
http://www.kettering.edu/~thor3026/h...lve/index.html
Graphical representation of step by step. By feel, I insert the whole amount of gaging in (say .15mm) and then tighten it down on that. After tightening the locknut I make sure that I can still slide the feeler in, and can't fit the next size up (.16 mm). For the .15mm there should be a good drag on the gauges. This is all right, but it's still your own fault if you mess it up. Valve adjustments are easy, but can cost a burnt valve if you mess them up.
Old Aug 19, 2001 | 01:34 AM
yoshi234's Avatar
I shoot brides
Default Re: Valve Adjustment HELP!!!! PLEASE@!!!!!!!!!!! (mojoGSR92)
yes, easy to do, but just as easy to fawk it up. Also make sure you do this when the engine is cold (or at least sitting for several hours)
-y
Old Aug 19, 2001 | 06:15 AM
Dipshit Dan's Avatar
Default Re: Valve Adjustment HELP!!!! PLEASE@!!!!!!!!!!! (yoshi234)
Here's a great site with directions on how to: http://www.c-speedracing.com/
Old Aug 19, 2001 | 09:53 AM
albert butterbikini's Avatar
New User
Default Re: Valve Adjustment HELP!!!! PLEASE@!!!!!!!!!!! (God)
Where can i get the snap on tool? Part #?
qpzm12
Jan 3, 2011 06:02 AM
rayatbhf
Aug 25, 2006 12:40 PM
600_Double_R
Jun 8, 2006 06:47 AM
White Lightnin
Mar 10, 2003 09:30 AM
Darren804
Aug 20, 2001 07:35 AM
