Overheating, where to start...
Old Aug 18, 2001 | 04:39 PM
DragII's Avatar
25 Year Member
Default Overheating, where to start...
My car is overheating during normal driving, moments after it has been turned on....
Any Ideas on where to start?
Plenty of fluid in the radiator...so the obvious is covered....
TIA
Old Aug 18, 2001 | 05:02 PM
Dr Pooface's Avatar
Default Re: Overheating, where to start... (DragIIcivic)
Thermostat?
Old Aug 18, 2001 | 05:08 PM
DragII's Avatar
25 Year Member
Default Re: Overheating, where to start... (Dr Pooface)
I dunno because if I'm at a light, the temp doesn't fluxuate...
Old Aug 18, 2001 | 06:10 PM
teq1816's Avatar
If your thermostat is bad, it shouldn't cause your temp to fluctuate at all. It should either stay very cool or overheat quickly. It sounds to me like your thermostat is not opening. Hope that helps.
Old Aug 18, 2001 | 06:19 PM
BreakStuff's Avatar
New User
Default Re: Overheating, where to start... (teq1816)
Actually.. if the t-stat is not opening it would make the temp guage fluctuate.. But I would guess that would all depend on the location of the coolant temp sending unit
and also the ambient air temperature...
Being that it is August you shouldn't see as much as a fluctuation as you would in the winter months.. so , don't rule out the t-stat yet....
Old Aug 18, 2001 | 06:31 PM
DragII's Avatar
25 Year Member
Default Re: Overheating, where to start... (BreakStuff)
Ok...I'll check that tommarrow.....
couple things...
1. just put new plugs in...although I don't see how that would affect it..they are colder than stock....
2. Car is about due for a new water pump...75k miles on it now
Old Aug 18, 2001 | 06:41 PM
DragII's Avatar
25 Year Member
Default Re: Overheating, where to start... (Teken)
didn't think so...but it was wierd how the problem started up right after I installed em....
I'll check out the thermo tommarrow..and I need to flush my coolent anyway...nows a good time...I'll let you know how it turns out.
What are some signs that the water pump is going bad?
DragII's Avatar
25 Year Member
BTW car is fine while driving, but overheats when stopped at lights
Old Aug 18, 2001 | 06:48 PM
DragII's Avatar
25 Year Member
I planned on changing it this month...but I didn't want to do it right now....
I'll check the other things first w/ my fingers crossed
Old Aug 18, 2001 | 06:53 PM
DragII's Avatar
25 Year Member
Old Aug 18, 2001 | 07:16 PM
figment's Avatar
New User
Is your electric fan commin on? Either the fan/fan switch or thermostat is bad.
Old Aug 18, 2001 | 07:17 PM
BreakStuff's Avatar
New User
mileage tells me your waterpump is still the factory OEM..
If the waterpump is bad, you would definately notice a considerable noise..
Check the radiator for any debris in the elements..
Make sure the cooling fan is working properly..
And for ***** and giggles, replace the t-stat.. : )
Old Aug 18, 2001 | 07:19 PM
lude&lascivious's Avatar
New User
is the fan turning on at a stop?
Old Aug 18, 2001 | 07:54 PM
DragII's Avatar
25 Year Member
Default Re: Overheating, where to start... (lude&lascivious)
hmm I'll get back to ya on that, to tired to go drive right now...
How much do thermostats run anyway?
Old Aug 20, 2001 | 08:05 AM
DragII's Avatar
25 Year Member
Ok update time.....checked the fan, thermostat, water pump all seem to check out...however the fluid in the radiator had dropped considerably topped it off and the car is fine...now the big question...
Where is the coolant going...no leaks, so I must be burning it....
Headgasket?
How can I check the headgasket besides a compression test?
Old Aug 20, 2001 | 08:14 AM
92CivicSiR's Avatar
New User
Thats it, compression check. But don't get upset, if you blew it out, then it's time to get that "SUPER TURBO REBUILD" that everyone wants to be able to afford. good luck finding out what is wrong.
Old Aug 20, 2001 | 02:50 PM
DragII's Avatar
25 Year Member
Default Re: Overheating, where to start... (92CivicSiR)
compression test goes down tommarrow...I'll keep you guys posted
Old Aug 22, 2001 | 02:49 PM
pmachan's Avatar
So what is the deal after the compression test?
I am having some colling trouble myself, I am thinking headgasket as well.
Old Aug 22, 2001 | 08:02 PM
BreakStuff's Avatar
New User
Default Re: Overheating, where to start... (Paul Machan)
Compression test is inaccurate for coolant leak problems, don't go there..
If you have followed the above and still have not come up w/ an answer..
Do a visual check for a a coolant/oil leak at the headgasket, concentrate on the intake side of the head..
You can do a coolant pressure check as well, this will identify a problem more accurately than a compression test, but may also create more of a leak as well if not done carefully....
Old Aug 23, 2001 | 06:16 AM
92sleepR's Avatar
New User
I had a very similar problem. I have a GSR in my 92 Hatch and i kept the original radiator. Well,.. It began to overheat just as you describe. I replaced the thermo with a 20 degree colder one but that didnt help either. I did a pressure test and it was fine so i ended up just replacing the radiotor with an OEM Del Sol VTEC replacement from Radiators.COM. it's a dual core unit with metal endcaps (as opposed to the shitty plastic ones from Honda).
That fixed the problem completely. No more overheating. Extended 90+MPH runs in 90 degree weather and the temperature gauge doesn't even move. The old radiator must have been badly clogged.
The best thing is that the replacement rad only cost me $130.
Good Luck!
Mike
Old Aug 23, 2001 | 10:15 AM
speedillusion's Avatar
New User
do you have a repair manual for your car?
I just recently told my girl to check leaks on the headers. Her Mazda 323 was overheating after a few hours of driving. I told her I'd get to it. Try to check it. I have an '88 supra T, which was overheating like heck, until we found out that one, the radiator hose was no good, two, the head gasket was practically blasted, then the bad thing happened, I found out that my whole block was mixing oil and water, this was because my whole block needed to be rebuilt. My parents ended up paying for it, to be rebuilt in my uncle's machine shop. There goes $1,500...
All I'm saying is, before it gets worse, get it diagnosed.
It could be, the radiator, bad thermostat, blown head gasket, etc.
danielblushtein
Jun 25, 2010 09:58 AM
Chuethou_b18c5
Mar 15, 2007 10:46 AM
s1ngle
Dec 12, 2005 05:26 AM
project-boosteD
Dec 24, 2004 05:53 PM
delSolLS
Jan 16, 2002 01:06 PM
