93 civic sedan upgrades
Old Sep 5, 2003 | 03:36 AM
catalina1959's Avatar
Default 93 civic sedan upgrades
Just picked up a 93 Civic lx w/ an auto and a shot motor..couple of questions
I am told best & cheapest swab is a 94-96 integra LS motor is this right ?
Also I want a 5-speed switchover, is this hard ?
I also have access to a 95 integra (wrecked) with a good motor but is an automatic,is an automatic motor the same as a manual motor ?
newbie from minnesota
Old Sep 5, 2003 | 05:29 AM
BauleyCivic's Avatar
Risky Business
Default Re: 93 civic sedan upgrades (catalina1959)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by catalina1959 &raquo;</TD></TR><TR><TD CLASS="quote"> Just picked up a 93 Civic lx w/ an auto and a shot motor..
cool...welcome to the club...i have a 93 LX...except it is manual and the motor runs perfectly
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by catalina1959 &raquo;</TD></TR><TR><TD CLASS="quote">I am told best & cheapest swab is a 94-96 integra LS motor is this right ? </TD></TR></TABLE>
not necessarily...unless you can find an LS swap cheap somehwere...i'd go with a JDM B16a SiR2. Only 2300 bucks, gives you 170 HP and VTEC.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by catalina1959 &raquo;</TD></TR><TR><TD CLASS="quote">Also I want a 5-speed switchover, is this hard?</TD></TR></TABLE>
yes...there is a lot of custom fabrication necessary and cutting and rerouting things
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by catalina1959 &raquo;</TD></TR><TR><TD CLASS="quote">I also have access to a 95 integra (wrecked) with a good motor but is an automatic,is an automatic motor the same as a manual motor?</TD></TR></TABLE>
no...the transmissions are obviously different, and the cams i believe are slightly different as well. I would take the 95 auto integra motor and put it in your car, it would be a LOT easier than converting from auto to manual...unless you REALLY want to go manual (like 99% of the people on this site would say)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by catalina1959 &raquo;</TD></TR><TR><TD CLASS="quote">newbie from minnesota</TD></TR></TABLE>
Old Sep 5, 2003 | 08:06 AM
EARLdaSQUIRREL's Avatar
official honda whore
actually its just as easy to switch to 5 speed then try to put an auto b series into his car
Old Sep 5, 2003 | 08:13 AM
Archidictus's Avatar
Unceasing Measure
Default Re: (coptzer)
Yeah, the B18B (Integra LS motor) is the most cost effective. The B16A Sir2 is a dragging bitch of a creature and doesn't make any real power until you rev it to 8400 rpms. I'd stick with the automatic LS and once you need more, go darkside and turbo it. 170 VTEC horsepower doesn't mean much when coupled with 90 foot pounds of torque.
The auto to manual swap isn't hard at all. All the holes are there, all you need to do is drill some of them through and mount the pedal and cable assembly. I've never heard of "custom fabrication" with a setup such as that.
Old Sep 5, 2003 | 09:09 AM
skribblah's Avatar
Default Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idiot &raquo;</TD></TR><TR><TD CLASS="quote">yes...there is a lot of custom fabrication necessary and cutting and rerouting things</TD></TR></TABLE>
no. your seriously wrong. its easy as banging a ding out of the shifter tunnel, plug in the clutch master cyl, bolt up pedals ( holes are already there) run hydrolic line from clutch master cyl to slave cyl on teh tranny, and connect shifter linkage.
idiots....
Old Sep 5, 2003 | 09:16 AM
Risky Business
Default Re: (skribblah)
i thought there were some issues with the mounts...
Old Sep 5, 2003 | 02:17 PM
which harness do i use civic or integra..
if i go 5-speed out of an integra do i need a 5-speed ecu and harness or will the auto one work
Old Sep 5, 2003 | 03:05 PM
skribblah's Avatar
Default Re: (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">i thought there were some issues with the mounts...</TD></TR></TABLE>+
oh yea and you eather have to get the HCP EG AT MT mount, from jdmshit $130 shipped. or you drill off the AT mount, and weld the MT mount on. $130 isnt a bad price....
but dont run without this mount, people have busted tranny housings and broken axles form not running with this mount.
XXXcooperXXX
Jan 10, 2007 07:13 PM
Performance Freaks EH
Feb 9, 2006 09:47 AM
REDSOL
May 3, 2002 11:30 PM
