Lakewood Traction Bars
Old Sep 5, 2003 | 12:48 AM
Boost2NA's Avatar
Default Lakewood Traction Bars
I found these on the internet for like 279.00. Its says they fit 92-00 civics with no mods at all. I have been researching the traction bars recently and came up with that the JimFab bars do not work on the 99-00 Si cause of the control arms. Does anyone know if the Lakewood Traction Bars will work. Here is the link. http://www.mrgasket.com/maildi...D=468
Old Sep 5, 2003 | 01:15 AM
ninesecrx's Avatar
Default Re: Lakewood Traction Bars (Boosted99Si)
They look like they would work with the 99-2000si because it looks like its just 1 tab that bolts to the lower fork bolt. The problem is see though is this is not correct geometry and would make for a possibly dangerous situation...the arms would be set out too far and straight. It might also tear away at the rubber in the lower control arm and be dangerous as well.
Old Sep 5, 2003 | 03:12 AM
Boost2NA's Avatar
Default Re: Lakewood Traction Bars (ninesecrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninesecrx &raquo;</TD></TR><TR><TD CLASS="quote">They look like they would work with the 99-2000si because it looks like its just 1 tab that bolts to the lower fork bolt. The problem is see though is this is not correct geometry and would make for a possibly dangerous situation...the arms would be set out too far and straight. It might also tear away at the rubber in the lower control arm and be dangerous as well.</TD></TR></TABLE>
Ok so what should I do here. Hope that Jim Fab comes out with some or go ahead and get the Lakewoods. Any info you have is really helpful.
-Leonard
Old Sep 5, 2003 | 04:13 AM
ninesecrx's Avatar
Well, take the info for what its worth. Jimfabs would be nice, but you would have to have a tab welded on. If you wont do that, get the lakewoods and run the risk of what I stated above.
Old Sep 5, 2003 | 12:59 PM
Boost2NA's Avatar
im gonna wait until Jim Fab makes some for the 99 coupes.
Hey, what you think about the Z10 traction bars for the civics. or
Old Sep 19, 2003 | 12:32 AM
96dc2's Avatar
Z10's have the wrong geometry also.
SOLtrain "tiiiteboyee"
Jan 24, 2008 03:42 AM
CRX 2.0V-T
Dec 7, 2006 06:58 AM
tthame1
Sep 2, 2004 02:51 PM
NonovUrbizniz
May 20, 2003 09:25 PM
Blk98Teg
Apr 22, 2003 11:07 AM
