Will the JDM ITR header fit my Si without a problem?
Old Aug 18, 2001 | 03:45 PM
00 Si's Avatar
New User
Default Will the JDM ITR header fit my Si without a problem?
I read some where that there is some modifications that you have to do to fit on a B16A2 but not sure. Can someone tell me if you have to modify anything or if it is a direct bolt up. Thanks in advance.
Old Aug 18, 2001 | 05:39 PM
DragII's Avatar
25 Year Member
Default Re: Will the JDM ITR header fit my Si without a problem? (00 Si)
It will bolt up to the head, but not the cat
Go aftermarket, much less headache...same if not better power gains
Old Aug 18, 2001 | 06:02 PM
RacerXI's Avatar
Default Re: Will the JDM ITR header fit my Si without a problem? (DragIIcivic)
What Drag said...you're either looking at an OBDII compliant test pipe * won't throw CEL* or a 2.5" carsound cat or something to that effect. Good luck with it.
Old Aug 18, 2001 | 07:13 PM
00 Si's Avatar
New User
Default Re: Will the JDM ITR header fit my Si without a problem? (RacerXI)
How much is the cat and where can I find it? Will it bolt directly to the aftermarket cat with no problems? What kind of modification am I looking at if I keep the factory cat?
Old Aug 18, 2001 | 10:40 PM
RacerXI's Avatar
if you keep the factory cat, you're looking at rebuilding the inlet to your cat to accept the 2.5" collector. If i were you, i'd just pick up a test pipe or 2.5" cat.....to think of it down the road, you may want to replace the header setup with your stock cat and exhaust manifold. You won't have it all hacked up. Try this place.....you might want to e-mail him personally to make sure it doesn't throw a CEL i hope it's not down right now http://www.godspeed.hack.net/
Old Aug 18, 2001 | 11:49 PM
ElectronVTEC's Avatar
The JDM 4-1 is a damned nice header. I can say for sure it'll support at least 200 whp . The nice thing is that with the factory heat shields, no one even notices the damned thing... plus its butt-*** ugly so do us all a favor and get the heatshields too. Peace, EV.
Old Aug 19, 2001 | 05:48 AM
00 Si's Avatar
New User
Default Re: Will the JDM ITR header fit my Si without a problem? (ElectronVTEC)
I have a Comptech header right now. Will it benifit me any to get the JDM piece or should I just keep the Comptech header?
Old Aug 19, 2001 | 05:54 AM
RacerXI's Avatar
I think unless you were planning on building a serious NA car real soon the comptech header will work just fine. The comptech header is a nice piece. Maybe EV can shed some light.
Old Aug 19, 2001 | 07:20 AM
DragII's Avatar
25 Year Member
The comptech should make more power than the stock JDM manifold....think about it....why would they sell header in japan if you wouldn't benefit from them?
Old Aug 19, 2001 | 08:04 AM
Uh, just cause they sell it doesn't mean it will work. Take the Pacesetter header... you think that thing actually makes power and *wont* fall apart in a year? Riiiight. As for the comptech vs JDM 4-1, the main reason to get the JDM is for the 2.5" collector as it seems to be more appropriate for cams that are larger than stock. The comptech isn't a bad header but can you honestly tell me they know more about B-series engines than Honda? That may sound like a weird reason but I used the JDM 4-1 because its engineered by the same people who designed the B-series engines. IMO, it was worth the trouble and I'm not even thinking about going to a high dollar JDM 4-2-1 as I dont see much of a gain to be had. Peace, EV.
Old Aug 21, 2001 | 02:38 PM
ITR764's Avatar
the deck hight on the b18c is higher than the b16, so the jdm itr header will hange lower.
Old Aug 21, 2001 | 08:58 PM
sloppy_seconds's Avatar
Banned
Default Re: Will the JDM ITR header fit my Si without a problem? (ITR764)
the jdm ITR header is mostly for high end use...this meaning that some of your low end torque will disappear when the header is installed. too much $ to modify your car install a header if you already have a comptech one!
--justin
Old Aug 21, 2001 | 10:07 PM
Kengs's Avatar
Good point. My favorite car wash place won't take my Si now
Still, you can't beat the bang for the buck, even if it is butt-ugly
1998teg
Jul 29, 2004 11:29 AM
tweekerz
May 10, 2002 11:59 AM
Bbasso
Feb 16, 2002 05:50 PM
Willard
Jan 16, 2002 03:21 PM
threatcon13
Nov 19, 2001 08:40 AM
