What cams for H22??
Old Sep 4, 2003 | 10:23 PM
Bowlergi21's Avatar
Default What cams for H22??
I just got an H22 in my accord and runs like a bat outta hell. I love it but want a little more kick when it hits vtec so what kinda cams do you guys recommend?
Old Sep 4, 2003 | 11:27 PM
whoa its len 2's Avatar
skunk2 stage 1
Old Sep 5, 2003 | 12:40 AM
NAR Cd7 Lude
Guest
Posts: n/a
Default Re: (whoaitslen2)
or you can go with Type S cams... both are good
Old Sep 5, 2003 | 01:10 AM
NA gs-R 05 C
Guest
Posts: n/a
Default Re: What cams for H22?? (Bowlergi21)
there arent many aftermarket cams out there for the h22, but like whoaitslen2
and NAR cd7 lude said, you can choose the skunk stage 1's or go with the jdm type s cams or if you wanna go a little crazier, you can go with skunk stage 2's which i believe is the strongest cams that skunk makes for the h22.
Old Sep 5, 2003 | 05:08 AM
Hondaaccordvtec's Avatar
Default Re: What cams for H22?? (NA gs-R 05 C)
If he went with the Skunk 2's - wouldn't a valvetrain upgrade be in order?
Old Sep 5, 2003 | 05:37 AM
Cheez's Avatar
Default Re: What cams for H22?? (Hondaaccordvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondaaccordvtec &raquo;</TD></TR><TR><TD CLASS="quote">If he went with the Skunk 2's - wouldn't a valvetrain upgrade be in order?
Old Sep 5, 2003 | 05:38 AM
Bantam's Avatar
2nd Coolest Person in DFW
yep
Old Sep 5, 2003 | 09:01 AM
biggs2.3's Avatar
JUN spec 2
Old Sep 5, 2003 | 03:36 PM
grocerygetter's Avatar
there are a few guys around here running Skunks and have loved em
Old Sep 5, 2003 | 05:45 PM
precord96's Avatar
cant forget the JUN's, they only came in one spec which was III. But they require the JUN dual valvesprings, and ti retainers are strongly recommended. But you cant do nothing but love the 296 degrees of duration on the vtec lobe (intake & exhaust)
Old Sep 5, 2003 | 11:48 PM
Broken Gearbox's Avatar
Default Re: (precord96)
I think EF-1's are making cams for the H22
Old Sep 6, 2003 | 10:08 AM
jarel's Avatar
Default Re: (James.)
Question - I heard that Type-S cams in a USDM head would tend to hit and wear away at the inside of the head after a while. Is that true? If so...is there anyway to get the Type-S cams to run right? P & P?
jinwoo
27
Aug 18, 2007 10:32 AM
94sisol
Sep 22, 2006 10:11 AM
