120kmi. turbo too risky?
Old Sep 4, 2003 | 07:13 PM
SL!M's Avatar
Default 120kmi. turbo too risky?
My honduh has 121k, supposidly mostly highway, i bought and only put on 8 myself so i dont know, but when i bought it it had many service records, all oil change records, and then car is in great shape. I hope to get pix soon to show u guys, but anywho, since the car is taken care of, u think if i put the greddy kit on it running about 8PSI it would be ok? Im just not sure.
Old Sep 4, 2003 | 07:14 PM
T4eg's Avatar
Default Re: 120kmi. turbo too risky? (mOuse)
You should be fine. I know people who had over 150K on their motor and still ran strong
Old Sep 4, 2003 | 07:18 PM
NonovUrbizniz's Avatar
Loved
I'd do a compression and leakdown tests... see what they result in and judge from there...
You may also want to consider changing your headgasket first... that way you can inspect the piston tops valve faces... check the block and head for warpage... change the gasket to a *EDIT*NOT THINNER THICKER*/edit* thinner one to lower compression if you want...
you'd have a MUCH better idea of the general condition of things in there...
You could do it w/o though...
Modified by NonovUrbizniz at 3:25 PM 9/5/2003
Old Sep 4, 2003 | 07:51 PM
ironcheftony's Avatar
i have 180+ and 202 compression all the way across on WOT, bout to turbo it =P
Old Sep 4, 2003 | 07:54 PM
rMak's Avatar
Default Re: (ironcheftony)
wait...a thinner headgasket lowers compression? i thought that if it was thicker, there would be more room, and that would lower the compression? someone help me out
Infinity_Racer's Avatar
yea def. do a compression test and a leakdown test...the amount of miles isnt really a BIG factor when deciding to boost a motor...i mean somone can have a 40k mile engine that was ragged on half of its life...
i'm put my greddy kit on at 175k and now i have 180 and going with a t3
Old Sep 4, 2003 | 07:58 PM
Kamin's Avatar
Default Re: (Infinity_Racer)
ill echo everyone else
compression and leakdown test. that will tell you what kind of condition the motor is in. thats the most important thing. miles are meaningless if the motor was taken care of. ive seen motors with 140,000 miles that look like they were just broken in, and motors with 20,000 that look like they have 200+k
Old Sep 5, 2003 | 06:24 AM
Loved
Default Re: (slowEJ8)
Yeah sorry... It was late and I mis-typed...
Thicker HG=lower comp.
Thinner HG=higher comp.
My bad.
Old Sep 5, 2003 | 08:21 AM
egmike's Avatar
Default Re: (NonovUrbizniz)
I have 220 Km on my stock d16z and have no problems boosting... nock on wood
Old Sep 5, 2003 | 09:26 AM
Newman's Avatar
New User
Default Re: (Mr8)
190K miles on my stock B18A.... just changed out the timing belt (cause my water pump was failing, so I changed both out) and still running strong for the past 4 months with my turbo, and it's daily driven with AC. When I take the motor out here shortly, I'll tear it down and check out the rings and headgasket and see how much abuse it really took.
Old Sep 5, 2003 | 09:30 AM
93preludeh22's Avatar
Honduh?
Old Sep 5, 2003 | 10:23 AM
-Trinitron-'s Avatar
Yeah you need to check the condition of YOUR motor. A motor can have 100K miles and be in excellent condition or have 50K and be shitty! Good luck though. I have 85K on mine..going turbo one day...I'm just going to be prepared for the worst!
250 posts! WOOHOO
Old Sep 5, 2003 | 11:09 AM
nigel's Avatar
who cares about miles, if it blows up. swap it.
Old Sep 5, 2003 | 03:28 PM
rMak's Avatar
Default Re: (nigel)
u swear a new engine doesnt cost money. swapping is downtime too. and you gotta go get the engine. just be safe.
Old Sep 5, 2003 | 08:53 PM
Default Re: 120kmi. turbo too risky? (-TRINiTRON-)
GO RACER X
GO SPEED RACER, GO SPEED RACER.. !
mikegsturbo
Mar 3, 2009 06:31 AM
white ej2
Dec 1, 2008 09:40 AM
Liquidgsr
Jan 13, 2006 04:40 PM
mplays
Sep 5, 2002 09:24 PM
