Doing your own suspension upgrade ,LCA bushing question
Old Sep 4, 2003 | 06:52 PM
ITR981002's Avatar
Default Doing your own suspension upgrade ,LCA bushing question
I've done suspension on a bunch of Civics and Tegs in the past. Every single car I've done the lower mounting bolt for the rear shock has frozen inside the LCA bushing and I need to replace the bushings. I know the bushings for the ITR are different than normal Civics or Tegs, have you guys had similar problems replacing the rear suspension on the ITR or is it not an issue. I just need to know if I should go ahead and order new bushings before I even start or if that is not nessesary. Specificly my car is a 98 ITR.
Old Sep 4, 2003 | 06:58 PM
arren123's Avatar
Default Re: Doing your own suspension upgrade ,LCA bushing question (gothatch)
When I installed my suspension @ 17,000 miles, I didn't have a problem with bolt getting stuck in the bushing. I just had to use a screwdriver and hammer to tap it out. Comes out pretty easily. <shrug>
GagnarTheUnruly
Apr 19, 2020 03:55 PM
Maxman
Suspension & Brakes
May 6, 2014 05:21 AM
s13hero
May 5, 2012 07:11 PM
hondastrtracr
Jul 29, 2007 01:37 AM
erebunicrx
10
Mar 12, 2005 06:45 PM
