Anyone with GodSpeed test pipe?!? Need Help!!
Old Aug 18, 2001 | 12:25 PM
onyx00's Avatar
Default Anyone with GodSpeed test pipe?!? Need Help!!
Okay, anyone else with experience with the GodSpeed test pipe? It won't fit for me. The screw holes that connect the test pipe to the B-pipe are too small! Any ideas? I would go with smaller screws buy then the b-pipe will most likely rattle. Any suggestions guys? I can get the test pipe holes drilled bigger, but just wondering if there are other alternatives before doing that.
Old Aug 18, 2001 | 01:31 PM
MikeD's Avatar
New User
Default Re: Anyone with GodSpeed test pipe?!? Need Help!! (onyx00)
I don't have one, but have you considered using small washers or bushings around smaller screws?
Old Aug 18, 2001 | 01:50 PM
SuspectProduct's Avatar
New User
Same problem I had. I had to drill out the holes so it would fit properly.
Also beware the O2 bunge. Placement is kinda crappy on mine.
Old Aug 18, 2001 | 02:32 PM
onyx00's Avatar
Default Re: Anyone with GodSpeed test pipe?!? Need Help!! (SuspectProduct)
Pleacement on mine sucks as well. Pretty tight fit in terms of the wires.
Old Aug 18, 2001 | 02:47 PM
Dipshit Dan's Avatar
I'll speak to the machine shop and let them know to enlarge holes a bit.
DA9Sleeper
Nov 5, 2009 01:39 AM
EGhatch33
May 1, 2006 09:37 PM
allmotorgizzles
Nov 1, 2005 01:10 PM
greenmonster
Honda S2000
Oct 20, 2004 04:04 PM
blktyper2001
Oct 20, 2001 11:53 PM
