code 23??
Old Sep 4, 2003 | 05:28 PM
shadowstylz's Avatar
Default code 23??
I have first gen b16 and a shop just replaced my headgasket just go the car back bout an hour ago when I start up the car and wait a little like about a minute a cel comes up its 2 long blinks 3 short ones, so Im think code 23 knock sensor?
were can it be located and do you think they forgot to plug it in tight? or would they have even touched it replacing a headgasket? any advice would be appreciated
Im runin a pw0 ecu and vtec is still hittin hard like a mother....
Old Sep 4, 2003 | 06:40 PM
Default Re: code 23?? (shadowstylz)
nobody can help me with my code 23?
Old Sep 4, 2003 | 07:33 PM
Lo-Buck EF's Avatar
try doin a search. i know i found a good list for the sohc codes. but i never seached for b series. also, just check the knock sensor/wiring and be sure its all plugged in snug.
-spenc
Old Sep 4, 2003 | 07:45 PM
VashTheStampede's Avatar
No tears. Only dreams, now.
knock sensor.
Make sure the wires are hooked up right. 91-93 octane. Check the sensor itself. Underneath the #2 intake runner.
If that doesn't work, call the place where you got the swap from... if it's hmotorsonline.com I'm sure they'd replace it after they check the pics.
sir2sol
Apr 1, 2005 04:55 PM
calgone47
Oct 6, 2004 11:46 AM
noob23
Aug 27, 2004 03:59 PM
TRhatchCRAP
10
Aug 10, 2003 11:52 AM
qwklude82
Jan 11, 2003 07:03 PM
