stock oil pressure?
what is the maximum the stock oil pressure should be at the stock sending unit location?
I have a freshly built motor and with new oil, cold start, the oil pressure was up as high as 60psi! it came down to about 20psi or so after it warmed up.
is that normal?
manual says minimum of 10psi at idle.
is that normal?
