dohc zc, high idle
Old Sep 4, 2003 | 02:25 PM
DesiDez's Avatar
Default dohc zc, high idle
even when my car is warmed up, the idle sits at 1.5k. i've alreadly tightening the idle screw all the way. i've come up with a checklist. do u guys suggest anymore?
1.hose/vacuum lines: make sure they go the right spot.
2.hose/vacuum lines: make sure there are no leaks
3.eacv: clean out
4.radiator lines: i heard if there is air here, this might be a problem. but how do u drain this out.
Old Sep 4, 2003 | 02:28 PM
firstgenrex's Avatar
ok the only thign i can help u with is bleeding the radiator lines. if u follow the large hose from the radiator, left center there is an aluminum nut/ u loosen the nut wait until coolant starts coming out, then tighten it. make sure ur car is cold
Old goat
Jan 1, 2012 07:09 AM
CRXguy_88
Sep 23, 2010 06:11 AM
1kleenef
Sep 30, 2007 10:09 AM
aakeobo
Jun 7, 2006 07:58 AM
