B-18 rod ?
Old Sep 4, 2003 | 12:55 PM
mild98's Avatar
Default B-18 rod ?
Will B-18 rod work in a D-16? A guy on ebay is selling a set of rod and that is what he is saying. The only thing he says you have to do is bushing the pin hole to smaller Dia.? Is this true??
Old Sep 4, 2003 | 03:17 PM
turbo sol's Avatar
Default Re: B-18 rod ? (mild98)
not that i am an expert but i have done this.
the small end of the rod must be rebushed to take the smaller d16 wrist pin.
the large end needs to be thinner, so that it fits in the journal on the crank.
I cant remember the exact measurements. but i will tell you that you will need a floating wrist pin set up on your new pistons.
Old Sep 4, 2003 | 09:50 PM
91 POS's Avatar
ttt
Also would doing this make it a D18A6
Old Sep 9, 2003 | 11:20 PM
91 POS's Avatar
ttt
Old Sep 9, 2003 | 11:38 PM
DohcVtecCrx's Avatar
Default Re: (91 POS)
rod length is the same, so it will not change anything once it is "made: to fit, it is just a beefier rod is all. No stroke diffrence
5genhatch
Engine Machining & Assembly
May 27, 2019 08:48 AM
jlfrnce
Sep 2, 2009 01:30 PM
Mad Cow Disease
Oct 2, 2003 01:55 PM
hybridb18
Aug 8, 2003 07:28 PM
satan_srv
Nov 21, 2002 09:18 AM
