Replacing Axles?
Old Sep 4, 2003 | 12:55 PM
Ladysman_civic's Avatar
Default Replacing Axles?
Ok, my axle boot is fucked up.. and i have to replace my whole axle to fix it.. im doing this on my 6th gen civic.. is there anyone that can give me some info on how to replace the axle??
thanks
Old Sep 4, 2003 | 01:00 PM
Spade's Avatar
Default Re: Replacing Axles? (Ladysman_civic)
Helms/Haynes.
Replace the axle. It is cheaper.
Old Sep 4, 2003 | 01:18 PM
aw1234dude's Avatar
Default Re: Replacing Axles? (Spade)
https://honda-tech.com/zerothread?id=382416
Old Sep 4, 2003 | 02:13 PM
Del Sol SiR's Avatar
I think you're gonna need some tools. Major one is the 32mm or 34mm socket to drive your hub nut out, you'll need an impact (air or electric) gun. It makes it a whole lot easier. Don't forget the ball joint puller tool too. The rest should be easy.
Type 56
Suspension & Brakes
Apr 4, 2017 09:30 PM
chris89
Transmission & Drivetrain
Aug 28, 2015 09:51 PM
93egsi
14
Jul 9, 2004 10:10 AM
arren123
Apr 13, 2003 12:54 PM
4doorH22
Apr 7, 2002 08:06 PM
